best layer hight for a 0.4 nozzle ?
May 18, 2015 03:05PM
what is the best layer hight for a 0.4 nozzle so there is a good balance of quality and speed ?
thanks Nikki
Re: best layer hight for a 0.4 nozzle ?
May 18, 2015 03:24PM
0.2 and 0.3
0.2 best quality
0.3 less printing time
May 18, 2015 03:25PM
Hi Nikki,
I have found 0.2mm to be the best for me in regards to speed and quality.
However, 0.1 gives very good prints!
Regards,
Alex
May 18, 2015 03:46PM
I use .2mm- .3mm
.1mm if I absoulutly need to but I rarely use anything that low.
May 18, 2015 04:38PM
Somewhere around .24 might work well, but your actual optimal layer height depends on your lead-screws as much as (or more than) your nozzle diameter. Check out Josef Prusa's calculator for Optimal Layer Height.
May 18, 2015 05:16PM
Thank You I will run some test prints tomorrow. I have been using 0.2 layer hight and have been getting very good prints but it is very slow it took over 5 hours to print just the body of a wades extruder but not having any experience am not 100% sure if that is just how long it takes.
Thanks Nikki
May 18, 2015 08:55PM
Nikki81
Thanks Nikki
sounds pretty normal, the process was never meant to be quick
-=( blog )=- -=( thingiverse )=- -=( 3Dindustries )=- -=( Aluhotend - mostly metal hotend)=--=( Facebook )=-
May 18, 2015 11:36PM
I print all ABS at about 40mm/sec and it seems to work ok. Scale the speed down for smaller prints and up for larger prints.
May 19, 2015 02:24AM
I'd be curious to know what speed others print at. I run 60mm/s (20 on first layer) with pla and getting quite nice prints at .3 layer height. enough so that I haven't scaled down to .2 yet.
May 19, 2015 06:37AM
I think I have found the perfect setting I have been testing 0.25 with the 0.5 test cube.
May 19, 2015 10:34AM
Nikki81
[attachment 54896 IMG_0601.JPG]
Sweet job. One caveat though...make sure that your layer value gives you integral steps ( [Steps/mm] / StepSize ) on your z-axis. If you end up with decimals, then there will be a rounding error and the part gets ripples.
May 19, 2015 04:11PM
his calipers say mm ;-)
May 19, 2015 05:14PM
lunarkingdom
He meant make sure your layer height is evenly divisable by the steps and pitch of your Zaxis threaded rod.
If he is using a 5mm threaded rod with a .8mm pitch then at a layer height of .25mm he will have an error of -.8mm over 10cm
M5 threaded rod likes layers that are even. Instead of .25mm (that would give rounding issues) .24mm or .26mm would be fine.
Edited 1 time(s). Last edit at 05/19/2015 05:15PM by Floyd.
May 19, 2015 05:19PM
Floyd
So almost nobody uses bed autotramming/leveling? I am asking because if you use it then your "virtual Z axis" is probably no longer vertical and the above precaution would no longer be so simple to apply.
Edited 2 time(s). Last edit at 05/19/2015 05:21PM by cristian.
May 19, 2015 06:23PM
Personally ive used auto bed level with and without and I found I had more issues and grief with it on the printer.
I manually leveled the bed using a machinest indicator and have not had to worry about a unleveled bed since.
Auto bed level in my opinion has its places but its no replacement for a properly setup printer.
May 19, 2015 06:27PM
Floyd
Sorry for the OT question: what (kind and model of) tool did you use specifically?
May 19, 2015 09:20PM
This is not the one I used but just about any dial indicator will work. Id shoot for one in .001" graduations
[www.amazon.com]
Dial indicators start at about 20-30 bucks and go into the many hundreds...
VTE
May 20, 2015 03:31AM
Floyd do you have a picture of your setup?
May 20, 2015 05:00AM
cristian
I periodically level the bed as accurately as I can using the levelling screws, however there is a slight twist in the Y axis which means that I can't get all 4 corners at exactly the same height. Also the bed seems to drift out of adjustment sometimes. I could probably fix both of these with a little work, however as long as the amount of error is no more than about 0.3mm, I am content to enable auto bed compensation when I do a large print.
May 20, 2015 04:00PM
VTE
Not on hand. I can however take a picture tonight.
Keep in mind I dont have the indicator on the printer, its only a temporary item for calibration not a permanent install.
May 22, 2015 11:26AM
Floyd is doing the same as myself. I level with a dial indicator and agree there is no substitute for a properly set up printer. Just my two cents.
May 22, 2015 01:31PM
yeah, I can't picture how the hell this thing works
May 22, 2015 02:39PM
I straped it to my carriage with the plunger on the bed.
Then i manually jogged the bed in the x and y axis and adjusted until I could travel the whole distance of the bed without much of a change. Most of the time it was .002"-.004" difference from the high spots and low spots of the glass after leveling manually.
May 22, 2015 04:29PM
Here is a picture of three runs that I did at three different z-axis slicing levels. Don't consider top infill. [forums.reprap.org]
May 22, 2015 04:41PM
Yeah, i saw this in another thread. but you said there you were running at 100mm/s? I normally run at .3 with 60mm/s and I'm really happy with my prints.
