I'm trying to create a new command in the firmware of Repetier. I'm using the firmware on a RAMPS 1.4. Using the test script RAMPS, I can turn on and off the PIN 9 and 10. But when I implement the code in the firmware of Repetier, the relay turns on, but turns off automatically.
Following codes:
Commands :: setRelay void () {
pinMode (10, OUTPUT);
digitalWrite (10, HIGH);
9998 case: // M106 Fan On
setRelay ();
break;
I did something similar using the speed of the fan and that worked just right, follows the command:
case 106: // M106 Fan On
setFanSpeed (com-> Hass () com-> S: 255, com-> hasp ());
break;
case 107: // OFF Fan M107
setFanSpeed (0, com-> hasp ());
break;
Does anyone know why the relay off alone? Since I sent a command to only call?
thank you
