Seeking resistor heater recommendations
Posted by leadinglights
May 19, 2015 02:37PM
On all of the hotends I have made to date I used Welwyn 7W W22 resistors which are 7mm diameter by 22mm long and I have never had a failure but am looking for something physically smaller to try to fit a whole bunch of hotends close together. I see that there are several makes fitting a 5.5mm diameter by 12.7mm long format which would be great - has anybody got types (Manufacture and range/part no) which they can recommend, or which to avoid.
Mike
Re: Seeking resistor heater recommendations
May 19, 2015 02:48PM
With a current controlled PSU, you wouldn´t need any heat resistor. Just use the aluminum body as heating element.
With a PWM signal it would probably work with the RAMPS and a standard voltage controlled PSU. ( Not tested yet!)
-Olaf
May 19, 2015 02:52PM
Most people use cartridge heaters these days, not resistors. You will find a wide range of 6mm cartridge heaters on ebay, and smaller one elsewhere e.g. here [reprappro.com].
May 19, 2015 03:22PM
I tried heater cartridges when they first came out but had 4 failures out of 5 - one burned out after ca 20 hours, one case short, one open circuit and one with a resistance of 13 Ohms. I would prefer to stick to resistors until I am convinced that there is a quality product on the market..
By the way, o_lampe, don't try your current controlled PSU idea, the power dissipation depends on the resistance - formula is Power = I squared R.
May 19, 2015 03:38PM
leadinglights
Or perhaps you need to find a better source especially if the 4 of 5 came from the same batch and/or source. I've never had an issue with a cartridge heater failing. The only time that I've ever had to replace them is for design considerations.
May 19, 2015 04:06PM
They actually came from two batches, both 24V and 12V - I originally mentioned the problem on this forum about a year ago [forums.reprap.org]
There are also two other factors to consider, I use 24V as far as possible and have not yet seen smaller cartridges in 24V. Also, an axial heater works better in my multi-extruder design.
I will try the heater that dc42 mentioned but I will reserve my options and mainly investigate resistors.
May 20, 2015 02:51AM
leadinglights
You´d need a low voltage/high current PSU for sure, like welding inverters. Only smaller...
May 20, 2015 04:55AM
leadinglights
RepRapPro does a 19V version, see [reprappro.com]. It should be OK on 24V if you restrict the maximum PWM.
May 20, 2015 06:49AM
Thanks dc42, I will send for one from RepRapPro to try. I suspect though that in the end I will in the end keep to resistors - one by Vishay (part number RWM041022ROJR15E1) is categorized all the way up to 450C.
o_lampe, The resistance of an aluminum hot end block made from a 1cm cube would be about 28 microOhms so to get it to dissipate 20 watts would take 2670 Amps - the wires would be too thick for me.
May 20, 2015 09:27AM
leadinglights
450C is a good maximum temperature, and the price is good too (GBP0.43 from Farnell). Getting good thermal contact between the resistor and the heater block won't be easy though, and I don't think the usual thermal transfer pastes are any good at those temperatures.
leadinglights
That´s a lot! But your plans were to build a hole bunch of hotends, so you could design them in a different way to give them much more resistance.
Especially where the heat is needed around the nozzle.
Probably this is one step too far for now...
-Olaf
May 21, 2015 04:48AM
dc42
leadinglights
I do have a tiny amount (0.5ml) of a pyrolytic graphite thermal transfer compound which is astonishingly conductive up to about 700C but probably have not enough for this job. I have been looking at Deepcool Z5 which is supposed to be good to 300 degrees but can't find in the U.K.
