Trouble with Firmware error when compiling- starting out building a new machine
Posted by kevincnc
May 19, 2015 04:34PM
Hi all, this is my first post. I'm building a fairly large machine with a RAMPS board. The mechanics and electronics are no problem (yet,) but I've never used or programmed an Arduino. I'm following the Marlin firmware setup instructions on the Wiki, but as soon as I change from 1 to 2 extruders I get this error when compiling-
Arduino: 1.6.4 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
temperature.cpp: In function 'void manage_heater()':
temperature.cpp:665: error: unable to find a register to spill in class 'POINTER_REGS'
temperature.cpp:665: error: this is the insn:
(insn 98 97 100 4 (set (reg/vconfused smileyF 103 [ pid_input ])
(memconfused smileyF (post_inc:HI (reg:HI 141 [ ivtmp.168 ])) [4 MEM[base: _101, offset: 0B]+0 S4 A8])) temperature.cpp:449 99 {*movsf}
(expr_list:REG_INC (reg:HI 141 [ ivtmp.168 ])
(nil)))
temperature.cpp:665: confused by earlier errors, bailing out
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
I tried to search but there is so much info out there, I'm still a little overwhelmed. Any advice would be appreciated.
Kevin
Edited 1 time(s). Last edit at 05/19/2015 04:45PM by kevincnc.
open | download - 3D Printer.JPG (379.1 KB)
open | download - DSC_0078.JPG (282.5 KB)
This is the error I get when I set #define EXTRUDERS 2
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
fastio.h:34: error: pasting "DIO" and "-" does not give a valid preprocessing token
{DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\
fastio.h:45:80: note: in expansion of macro '_WRITE_C'
#define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0)
fastio.h:68:23: note: in expansion of macro '_WRITE'
#define WRITE(IO, v) _WRITE(IO, v)
temperature.cpp:1270:52: note: in expansion of macro 'WRITE'
if(soft_pwm_1 > 0) WRITE(HEATER_1_PIN,1); else WRITE(HEATER_1_PIN,0);
In file included from Marlin.h:21:0,
from temperature.cpp:32:
pins.h:687: error: invalid suffix "_PIN" on integer constant
#define HEATER_1_PIN -1
fastio.h:17:26: note: in definition of macro 'MASK'
#define MASK(PIN) (1 << PIN)
temperature.cpp:1270:58: note: in expansion of macro 'HEATER_1_PIN'
fastio.h:39: error: pasting "DIO" and "-" does not give a valid preprocessing token
{DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\
pins.h:687: error: invalid suffix "_WPORT" on integer constant
fastio.h:39:51: note: in definition of macro '_WRITE_C'
fastio.h:30: error: pasting "DIO" and "-" does not give a valid preprocessing token
#define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
fastio.h:45:105: note: in expansion of macro '_WRITE_NC'
fastio.h:30:48: note: in definition of macro '_WRITE_NC'
fastio.h:30:105: note: in definition of macro '_WRITE_NC'
fastio.h:45: error: pasting "DIO" and "-" does not give a valid preprocessing token
temperature.cpp:1292:30: note: in expansion of macro 'WRITE'
if(soft_pwm_1 < pwm_count) WRITE(HEATER_1_PIN,0);
pins.h:687: error: invalid suffix "_RPORT" on integer constant
fastio.h:45:44: note: in definition of macro '_WRITE'
temperature.cpp:1292:36: note: in expansion of macro 'HEATER_1_PIN'
fastio.h:34:51: note: in definition of macro '_WRITE_C'
temperature.cpp: In function 'void __vector_22()':
fastio.h:45: error: 'DIO' was not declared in this scope
temperature.cpp:1270:24: note: in expansion of macro 'WRITE'
On another forum I was told that this is a compiler error
