How to calculate correct voltage for stepper driver ?
Posted by Nikki81
May 24, 2015 11:33AM
How do I calculate the correct voltage for my stepper drivers ? I have had a look at the wiki but I don't understand(I am not good with numbers) is it amps x inductance = voltage ?
Thanks Nikki
Re: How to calculate correct voltage for stepper driver ?
May 24, 2015 11:43AM
If you have "r100" shunt resistors on your driver ( most common) you can skip the math and say 0.4V equals 0.4 A
-Olaf
May 24, 2015 11:54AM
Thanks looking at one of my spare driver boards the r1 says 303 ?
Thanks Nikki
May 24, 2015 12:14PM
Not R1,
it´s one of the resistors marked on my picture ( red or blue box )
-Olaf
open | download - shunt_location.jpg (95.6 KB)
May 24, 2015 01:25PM
Thank You there are r100 ill get tweaking !
thanks Nikki
May 24, 2015 03:16PM
Nikki81
Thanks Nikki
Nikki,
Close, right stadium, wrong seat.
For DC, it's Volts = Ohms * Amps. For AC, it gets a tad more complicated but boils down to Volts = Impedance * Amps. Impedance is a function of the frequency applied working against inductance, capacitance, or a combination of the two. When in full step mode, it is just pure DC with the stepper in current limit.
The resistor that is being spoke of is the current sense resistor that the stepper driver uses to monitor the amount of current going out to the stepper. It can be any value but it needs to be known to set the reference voltage for the stepper correctly. The supplier of the modules should be able to tell you what the value is or you will have to measure it. In the case of my Pololu DRV8825's, the reference voltage is 0.5 volts for 1 amp current limit. On this board, all I had to do was put one lead of my meter to ground and the other on the shaft of the screwdriver to make contact with the wiper and just adjusted for 0.5 volts. Did that and walked away from it.
