Dual Extruder for 3d printer
Posted by john G
May 27, 2015 11:34AM
I have megatronics v2.0 & i cant control the second extruder from LCD ( move axis ) there is any solution ?
THANKS smileys with beer
Anonymous User
Re: Dual Extruder for 3d printer
June 01, 2015 05:45PM
Surely move axis moves both extruders at the same time?
June 04, 2015 04:40PM
NO, Just one of them !
Anonymous User
June 04, 2015 07:13PM
Axis generally means X, Y or Z. Do you mean extrude or retract filament? What kind of printer do you have? Have you configured Marlin with multiple hot ends? You're not giving us much information to go on.
June 05, 2015 08:18AM
I have dual extrudes and i configurated marlin
I modified the number of extruders and the temp sensors 2
When i want to try the extrudes from LCD i found in move axis just the first extruder.
Anonymous User
June 05, 2015 10:23AM
Move axis means move in X, Y and Z planes. Do you mean extrude instead of move axis?
June 05, 2015 10:50AM
Yes
June 05, 2015 02:59PM
Only one extruder can work at any time. To switch between them you can use gcode (T0, T1). If you know a bit about how to adjust the firmware you might be able to add a switch between extruders to the menu.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
