finally happy got a working print but
Posted by trist077
May 27, 2015 02:04PM
right finally got print 20mm test square using slic3r and ponterface instead of repetier
the only thing is its not quite centre
echo cold extrusion prevented error in pronterface and temp is down from 188 set to 176
a few gaps in cube
the cube has a 20mm height but length is 25mm even though set at 20mm
can you help me now feeling happy now its printing
Re: finally happy got a working print but
May 27, 2015 03:21PM
trist077
Sounds like you have the steps/mm on the X and Y axes set 25% too high in the firmware configuration.
May 27, 2015 03:46PM
sort the cold error fans were on
but how do i stop the holes in the cube
and the bottom layer no where near as good as top
May 27, 2015 03:49PM
trist077
It's hard to tell what the problems are without some photos.
