Theorethical (math) questions about spur gears July 12, 2010 03:41PM |
Re: Theorethical (math) questions about spur gears July 12, 2010 06:05PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Theorethical (math) questions about spur gears July 12, 2010 06:53PM |
Re: Theorethical (math) questions about spur gears July 13, 2010 02:14AM |
Re: Theorethical (math) questions about spur gears July 13, 2010 02:55AM |
Pitch circle diameter = number of teeth * module / pi
> Base circle diameter = number of teeth * module * cos(20deg)
This is not correct either. It is the root circle diameter.
original posting
In that case base diameter [DB] is smaller then root diameter [DR] !
Re: Theorethical (math) questions about spur gears July 13, 2010 04:02AM |
Re: Theorethical (math) questions about spur gears July 13, 2010 06:33AM |
Re: Theorethical (math) questions about spur gears July 13, 2010 06:43AM |
(I use a=m, while he is using somewhat smaller).
Re: Theorethical (math) questions about spur gears July 13, 2010 06:46AM |
Re: Theorethical (math) questions about spur gears July 13, 2010 06:49AM |
Also when the Root diameter is bigger then the base diameter, I made the two diameter equal.
Re: Theorethical (math) questions about spur gears July 13, 2010 06:52AM |
Re: Theorethical (math) questions about spur gears July 14, 2010 10:18AM |
Re: Theorethical (math) questions about spur gears July 18, 2010 02:49PM |
Admin Registered: 15 years ago Posts: 730 |
Re: Theorethical (math) questions about spur gears July 18, 2010 07:18PM |
Re: Theorethical (math) questions about spur gears July 20, 2010 12:11AM |
Re: Theorethical (math) questions about spur gears July 20, 2010 07:41AM |
Re: Theorethical (math) questions about spur gears August 19, 2010 01:59PM |
Re: Theorethical (math) questions about spur gears August 19, 2010 05:41PM |
questions about gear wheel November 20, 2011 06:36AM |
Re: Theorethical (math) questions about spur gears November 20, 2011 06:52AM |
