Hello!
I am almost done building my Mini Mendel and just have to finish the extruder before I can do my first test print. I need to connect the extruder controller to the motherboard, connect the extruder heater and thermistor wires to the extruder controller, and attach the Bowden tube at both ends (still pondering that). I hope to finish that today. Everything else seems to be working quite well which brings me to my current point of confusion with the software options.
I am using the TechZoneRemix electronics. I recalled reading somewhere that they came loaded with firmware for using ReplicatorG, so I uploaded the official RepRap firmware into both the motherboard and the extruder controller. I installed the RepRap host software and Repsnapper to tinker with throughout the build. I became more comfortable with Repsnapper. So without the functioning extruder, last night, I sent a print job to the Mini and watched the 3 axes do their thing . . very exciting. At times, it would hang waiting for a temperature reading, but I could hit the "Kick" button and it would resume.
Having read about the additional features in Skeinforge, I decided to tinker with that as well. So I used it to create some G Code for an object but then used RepSnapper to control the printer. It did seem to work, but without an actual print, I don't know if it worked correctly. There were some errors that I think were about unrecognized commands (M103 I think was one). So I have the following questions:
1. Which host should I use with Skeinforge? RepRap, RepSnapper, ReplicatorG, something else I don't even know about?
2. If I use ReplicatorG, do I need to replace my firmware?
Ideally, I would like to stay in sync with the "official" RepRap development of the Mendel and that's where my confusion is probably coming from. It seems that many or most of the people that are producing the best results are also using Skeinforge. If I have to jump to different firmware, what future RepRap developments might I be missing out on? The whole RepRap concept is fascinating to me, but in practice development seems so fragmented. Especially given the learning curve and tweaking needed to produce good results, I don't want to jump on the "wrong" path and have to go through that process twice.
So any advice in this area of software choices would be appreciated. Oh . . and while I program on non-GUI Linux servers all day, for convenience I'd prefer to stick with Windows. My astronomy/astrophotography laptop will have to double as my RepRap computer.
Thanks!
Kevin
