Hotend melting problem June 01, 2015 03:04PM |
Re: Hotend melting problem June 01, 2015 03:22PM |
Re: Hotend melting problem June 01, 2015 03:33PM |
Re: Hotend melting problem June 02, 2015 12:55AM |
Re: Hotend melting problem June 02, 2015 01:50AM |
Re: Hotend melting problem June 02, 2015 04:33AM |
Re: Hotend melting problem June 02, 2015 03:17PM |
Do you think all this problems would be solved by buying an V6 ?
Re: Hotend melting problem June 02, 2015 03:53PM |
Re: Hotend melting problem June 03, 2015 04:25AM |
o_lampe
When the nozzle is hot and you push filament from the outside against the nozzle, does it melt easy?
If yes, you probably have a blocked nozzle.
If not, you have a wrong temperature setting.
First of all, I wouldn´t trust your temperature reading.
What thermistor version did you choose in firmware?
-Olaf
Re: Hotend melting problem June 03, 2015 10:08AM |
Re: Hotend melting problem June 03, 2015 10:12AM |
