Consequence of shorting two pins on a Driver Board while adjusting
June 01, 2015 05:50PM
Small spark was seen
Just happened to me twice today. I need to start using a plastic screw driver to adjust the vrefs
Edited 1 time(s). Last edit at 06/01/2015 05:51PM by XYZM.
Re: Consequence of shorting two pins on a Driver Board while adjusting
June 01, 2015 05:55PM
I know for sure it damages the driver board(my first incident)... but does it cause damage to the actual board?
The 2nd time it happened it was with the a ground pin so I got lucky, because the driver board still worked.
June 01, 2015 06:11PM
That's one of the problems with those little plug-in driver boards. It's easy to kill them by shorting out traces with a screwdriver when trying to adjust the pot, and it's really easy to break the pot. It's best to keep a few spares handy- they're cheap enough.
If you ever get tired of dealing with those problems, check out the Smoothieboard. Among its many nice features are digitally controlled motor currents- you specify them in the config file and don't have to adjust any pots.
June 01, 2015 06:25PM
I have read about the smoothieboard, once I get more experience I will probably update.
For now I can't get anything to print. Motors move fine through manual control. But when heating the extruder and heatbed they studddddder. Geeetech thinks its power unit, so they will send me one. Im trying to make them send me another board too haha
June 01, 2015 06:26PM
Who is a good provider of the smoothieboard?
June 01, 2015 06:51PM
Another 32-bit board with software-controlled stepper motor current is the Duet. It's available at [www.think3dprint3d.com], [reprappro.com], and [www.replikeo.com]. It has probably the best firmware for controlling delta printers of any board at present, and also supports Cartesian and CoreXY designs.
June 01, 2015 07:43PM
Uberclock sells them in the US.
June 01, 2015 09:43PM
I use a ceramic tipped diddlestick to adjust the pots. Meter ground is attached to circuit ground by fleaclips and the other probe tip rides the pot wiper.
June 01, 2015 10:57PM
I use to have a fiberglass small screwdriver for these kinds of things. One advantage to the fiberglass version is that it you damaged the end you could fix it again on a grinder.
June 01, 2015 11:38PM
I actually just made a tool from an old ipod opening tool, by using a grinder. Lesson learned haha
