lunarkingdom
I run mine from the power supply.
Yes - there is no real advantage to powering an always-on fan through the RAMPS. Also note that the image labeling above is a bit misleading. The thing labeled "electronics fan" is actually the power input to the RAMPS board. However, you CAN tap off of here to power anything that uses 12 volts (provided your PSU has capacity). This includes both an electronics fan and an always on extruder fan.
