Removing a +1mm over size scale. June 04, 2015 02:06AM |
Re: Removing a +1mm over size scale. June 04, 2015 02:26AM |
Re: Removing a +1mm over size scale. June 04, 2015 02:40AM |
Re: Removing a +1mm over size scale. June 04, 2015 01:32PM |
o_lampe
When I measured a test cube, I always got more than one size. Differing from eg. 19.678 to 20.123mm
You´re saying 21mm. Period.
That sounds unrealistic to me. You should use a caliper to measure.
If there really is a constant 5% error in scale you only have to reduce the steps/mm in Marlin FW for x,y,z by 5% and you´re done.
-Olaf
Re: Removing a +1mm over size scale. June 06, 2015 01:02PM |
Re: Removing a +1mm over size scale. June 06, 2015 01:47PM |
Re: Removing a +1mm over size scale. June 06, 2015 03:40PM |
Re: Removing a +1mm over size scale. June 07, 2015 01:31PM |
