Wiring Gauge June 10, 2015 02:05AM |
Re: Wiring Gauge June 10, 2015 03:09PM |
Re: Wiring Gauge June 10, 2015 05:28PM |
Re: Wiring Gauge June 10, 2015 07:28PM |
Re: Wiring Gauge June 10, 2015 10:28PM |
Re: Wiring Gauge June 11, 2015 09:41AM |
The wire gauge you need to used is determined by the amount of current that will be flowing through the wire, not the voltage. Divide the wattage of your heater by the voltage to determine the current it will draw. So if you have a 40W cartridge, it would draw 40W/24V = 1.67 amps. Voltage and current have an inverse relationship when power remains constant. If voltage doubles, current drops in half. So you actually can get away with using a smaller wire (higher gauge) with a higher voltage.Quote
simspeed
Thanks CDRU... I'm running a 24V PSU and the E3d Cyclops heat cartridge is 24V also. Should that take a lower gauge wire?
Smaller wire will have a smaller bend radius of the same wire type. If they are different wire types (solid vs stranded, different insulation, etc) then it can vary.Quote
I have long travel in every axis so will be using some form of cable chain to keep all the wiring tucked away. The 14 AWG power cord appears to have a natural 4" diameter to the loop end, so 16 or 18 AWG bundled wire running in the cable chain should reasonably be less don't you think? Thanks....
Re: Wiring Gauge June 11, 2015 11:59AM |
