1 Meter bot project June 11, 2015 12:46PM |
Re: 1 Meter bot project June 12, 2015 11:39AM |
Re: 1 Meter bot project June 12, 2015 04:24PM |
Re: 1 Meter bot project June 12, 2015 04:35PM |
Re: 1 Meter bot project June 12, 2015 05:33PM |
oak1477
There will be a heated bed, which we have custom ordered for the bot. It is a silicon rubber heating pad. Yes it will require a lot of power (like 2500 watts)
it will be similar to this, this is one of the 2 foot beds
Re: 1 Meter bot project June 12, 2015 10:10PM |
Re: 1 Meter bot project June 15, 2015 09:49AM |
Re: 1 Meter bot project June 15, 2015 10:13AM |
Re: 1 Meter bot project June 15, 2015 10:20AM |
Re: 1 Meter bot project June 16, 2015 10:53AM |
Re: 1 Meter bot project June 17, 2015 07:01PM |
Re: 1 Meter bot project June 17, 2015 07:07PM |
Re: 1 Meter bot project June 17, 2015 07:41PM |
Re: 1 Meter bot project June 18, 2015 04:13AM |
Re: 1 Meter bot project June 18, 2015 10:01AM |
Re: 1 Meter bot project June 18, 2015 07:22PM |
Re: 1 Meter bot project June 18, 2015 07:26PM |
Re: 1 Meter bot project June 19, 2015 10:52AM |
Re: 1 Meter bot project June 19, 2015 12:38PM |
o_lampe
I´m wondering how such a huge frame is getting along without any diagonal struts? They would reduce the load on all the vertical struts alot...
-Olaf
Re: 1 Meter bot project June 19, 2015 01:02PM |
Re: 1 Meter bot project June 19, 2015 03:01PM |
Re: 1 Meter bot project June 19, 2015 03:41PM |
oak1477
Also, just out of curiosity what would you consider a acceptable amount of deflection.
Re: 1 Meter bot project June 19, 2015 04:03PM |
Subsequent layers generally have similar toolpaths so deflection will have the same effect on each layer (effectively making it invisible unless you are getting resonance/ringing).
Re: 1 Meter bot project June 19, 2015 05:20PM |
Re: 1 Meter bot project June 19, 2015 05:30PM |
Re: 1 Meter bot project June 19, 2015 05:33PM |
Re: 1 Meter bot project June 20, 2015 03:05AM |
JamesK
Perhaps a big printer is mostly going to be used with a 1mm nozzle and .8mm layers, in which case the accuracy requirements could presumably be relaxed somewhat.
Re: 1 Meter bot project June 20, 2015 03:32AM |
o_lampe
As a customer I wouldn´t accept a big print where the errors are also" scaled up".
I´d expect the same sharp corners and flat surfaces as with a common 0.4mm nozzle.
-Olaf
Re: 1 Meter bot project June 20, 2015 04:16AM |
cristian
o_lampe
-Olaf
It is impossible to obtain the same sharpness on Z with different nozzle diameters. A 1mm nozzle will always give you rounded corners with a radius of at least 0.5mm.
Re: 1 Meter bot project June 20, 2015 01:23PM |
