1 Meter bot project
Posted by oak1477
Re: 1 Meter bot project
June 20, 2015 01:48PM
garyhlucas
If you claim a positioning accuracy of 0.005" then the deflection had better be much less than that or combined with lots of other factors you can't possibly get that kind of accuracy. Note that deflection in the frame will produce a position error that will be huge for small parts and probably much less for very large parts.
Good point. The printer should be matched to the size of the parts it is going to print. Printing tiny parts with a huge printer is not only sort of silly, but likely to yield poorer results than printing the same part with a much smaller printer, all else being equal.
June 20, 2015 04:30PM
garyhlucas
I would relate this argument more to layer height and width than to the global size of the part to be printed, in particular if it has sharp corners.
Of course layer height and width may in turn be considered proportional to the size of the printed part.
June 25, 2015 12:11PM
Hello everyone,
Sorry it has taken so long for another update it has gotten super busy for me recently. We ended up having to completely redo the assembly of the cad, and that took a few days. We also finally have received the new extrusions for the x axis and and were unsure if just the 40x40 extrusion would cut it so we decided to do some deflection test on it (we also saw how interested some people were in this).
here is the rig we set up for the deflection and a few pictures of the test in general.
so we tested a 60x40 and the 40x40 extrusion with and without linear rails here is the data we got, we have decided to move up to the 60x40 extrusion for our x axis
June 25, 2015 04:02PM
Well done!
What about horizontal shear?
June 30, 2015 11:26AM
Hey guys sorry for the silence this weekend i was at a robotics competition. Do not worry more testing will be coming soon and we will be sharing all of our results with you. At the moment we are machining some parts so i wanted to update on that and later today I will be posting more photos.
Have a great day and keep printing.
June 30, 2015 06:19PM
Hey guys as promised another update today
I got some more parts ready we have the actual motors mounted to the extruders
we also did your first fit of all of the major parts of the x axis including the belts
June 30, 2015 07:22PM
Looks fantastic. Thanks for posting the results of the deflection tests - great info. I can just imagine how much flex there would be in 20x20! What's the weight of the print head likely to be?
July 01, 2015 03:59AM
Had a nice party? smileys with beer
First thing I recon´d were the white balloons grinning smiley
Seriously:
Aren´t you afraid the long belts eventually start to swing, when they are unsupported all the way back?
I thought of a different way to mount the extruder assembly, where both sides of the belt are fixed/guided.
-Olaf
July 01, 2015 10:14AM
o_lampe
Seriously:
-Olaf
We actually had a guy in the office with a birthday so we had set up some decorations and a cake for when he got in, and I would love to hear your idea further on the belts.
July 01, 2015 10:29AM
Belt resonance is an interesting idea Olaf! I'd build it first and then use a video camera to see if the belts were moving around much. No point adding hardware until you confirm the problem exists.
July 01, 2015 02:32PM
o_lampe
-Olaf
Thats why a lot of larger machines have a rack and pinion setup...
July 02, 2015 06:41PM
Hey guys update time. Been working hard all day and the cable trays are on the bot for the first time
thanks guys have a great 4th of July weekend and happy printing
July 06, 2015 07:22PM
Hey guys another update on the bot
I did some revisions on the design to how the y belts attach to the top bar. We were originally going to use some sheet metal flanges, but decided that was too complicated and time consuming. We settled on 3/8" angle iron as a possible solution that would be easier to work with. I designed a simple bracket and we printed it to test fit everything. Below are a few pictures of some of the y axis stuff
July 08, 2015 06:17AM
I have seen some large 3D printers on the net, and some of the larger stuff they build in this build space can take up to 72 hours.(depending on object) Dont think i would have that sort of patiencesmiling smiley. Keep up the good work, coming along nicely.
July 08, 2015 06:57AM
I like the design for the belt tensioner. I've been making all sorts of a mess around that. Yours is much simpler and tidier. Time to hit the mill again!
July 08, 2015 08:16AM
There's a 3D printable belt clamp that looks a lot like that tensioner here: [www.youmagine.com]
July 08, 2015 08:46AM
-wrong thread, sorry smiling smiley
-Olaf
Edited 1 time(s). Last edit at 07/08/2015 08:50AM by o_lampe.
July 08, 2015 06:43PM
JamesK
Same here. Great job on the design. Can't wait to see how everything turns out! This is one hell of an internship!
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
July 10, 2015 09:46AM
Hey guys update time, sorry these past few days have still been crazy here in Houston but i finally got some cool stuff to show you.
First off i know that this isn't the meter bot but a fellow intern just finished the frame of a bamboo and 3d printed bike so I had to share just a photo of that
Now for the printer, I have been working pretty hard to get as much into the CAD as possible so earlier this week inserted all of the cable trays
Here is my favorite render of it:
I also made some changes to the cover for the hot end assembly. We ended up going with a larger cover to hide all of the wiring that was coming into the assembly. I am pretty happy with the finished look of the cover
and finally, we got the extrusion for the top cover so I assembled that and installed it. The printer is now officially taller than me
Thanks guys for everything. Have a great weekend and happy printing
July 13, 2015 05:12PM
hey guys another update we just got the side panels in and test fitted on the bot. We are going to send them off to be finished and then we will begin final assembly.
July 13, 2015 08:05PM
I'm only guessing, but it looks like you still don't understand the meaning of stiff.
July 13, 2015 08:26PM
garyhlucas
We are still just test fitting parts, once everything is assembled we are going to be doing deflection testing on the frame. We have yet to fully assemble the frame so there has been no point in testing a frame that is just test fitted together. If our design is not stiff enough we will be changing it.
July 14, 2015 05:19AM
I don't want to sound like a sourpuss and dampen your obvious enthusiasm with this project, however I have a few objections about it that i would like to convey here.
The first thing is, this is clearly a closed source project by a company that uses open source hardware and firmware in its products, however has returned very little or even nothing to the open source RepRap community.
Second thing is, you are clearly posting this thread as a promotional stunt, since the design and build of a 1-meter FDM is clearly beyond the means and practical use by 99.99% of all RepRappers. And personally I find that the promotion of a closed source product in an open source forum is very disturbing.
The third thing is, as has been noted before in this thread, your project as it stands has very little technical merit, and I would even argue that you are setting a very bad example with your "design as we go" build method. For example, deflection of an aluminum profile can be calculated in advance, yet there is no indication or mention that you have done any engineering calculations in advance for your project, before your build started.
oak1477
Doh!
The fourth thing is, apparently this one meter cube bot is a dumb (sorry, no other way of putting it) linear upscale of your 60cm cube bot main product. This gives the false impression that 3D printers can be easily upscaled, which is an absolute fallacy.
The fifth thing is, I have serious doubts that current FDM printer technology is even remotely practical for objects that exceed 30cm in any direction, not to mention 60cm. At the 1 meter scale, there are no doubts, it is a certainty: current FDM technology is useless.
Summarizing, I really think you should create a blog on your company's website and post about your closed source commercial project in it. Then simply post a link in this forum to your blog, for those that may eventually be interested, however uninformative and misleading your blog may be.
July 14, 2015 08:19AM
Just to offer a different opinion, I'm delighted to see this project discussed here. Everything I do is heavily cost constrained and I think it's fascinating to see a project undertaken with the resources of a printer manufacturer behind it.
I know there are always emotional and political issues at stake in the open vs closed arena, but I don't see any actual harm in this thread being here. And I can't help but feel that some of those issues may be colouring your response to the project itself. If I understand correctly this is an internship project conducted by a capable but less experienced person and likely within a limited time-span. Under that scenario some of your objections regarding approach and technique seem a little unreasonable.
I'm confused about your suggestion of 30cm as an upper limit for FDM. The use cases and characteristics may be different from smaller printers but I'm curious why you think it is "useless"?
July 14, 2015 08:49AM
JamesK
James,
Everybody is free to have their own opinions and express them politely. So thanks for expressing yours.
There is no upper theoretical limit for FDM, you can print a km long object if you want to. However, in practical terms, the vast majority of 3D printable designs are limited to a 1l cube, as you can observe by yourself by checking the thousands of designs available on Thingiverse.
The reasons for this could be the object of a separate thread with several pages of arguments and counter arguments, so I'll stop here. If you want to dig further into this issue, just create a thread in the forum of your choice and I'll contribute as my time allows.
July 16, 2015 07:24PM
Lets keep it positive guys.
This thread is valuable - as long as you continue posting about your experiences and the required fixes After the build is complete - what happens when you actually attempt to print big with it is what's important.
Many people want to build large and need to know the pitfalls. Having built a large printer entirely from scratch I know this process is not easy, so I applaud your efforts!
I see several issues you will have to deal with:
- Resonance from your stepper drivers with Nema 23's - you will likely need tune-able drivers. Make sure the manufacturer has up-to-date software to tune them - that they support, and a cable that will connect to a modern computer ( USB ).
- Bed flatness. If you are using a cast aluminum tooling plate then you might be OK. A rolled-aluminum plate that large is going to warp when you heat it (or you could just print PLA).
- Accurate bed leveling - but you would know this already from your other large models.
My printer: Raptosaur - Large Format Delta - [www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the Wiki!
July 16, 2015 08:17PM
I don't think that upscaling a printer is quite the difficult thing that some make it out to be (I did it on a smaller scale than this). I think FDM can be useful in any size as long as you can live with the limitations. I doubt the intent is to print 50um layers with this beast, so if it flexes a little, it really doesn't mean it's useless, it just means they'll need to use thicker layers- but at this size, thicker layers are in order anyway so that print times don't become impractically long.
What difference does the closed/open source nature of the company's other products make in relation to this build for which they are providing detailed information on their successes and failures as they progress? I am thankful to see how they are doing things because I may one day decide to build something like this. Knowing some of the problems and their solutions in advance will save myself and others a lot of time, effort, and money. Who would be against that?
Finally, this forum isn't just for people who can only afford $300 kits- I'll bet there are plenty of people here with the resourcefulness/finances that would allow a build like this. Anyone who finds this thread offensive to their sensibilities has the option of simply ignoring it.
July 18, 2015 11:49AM
I enjoyed following this topic along and i'm very curious in seeing this one printing smiling smiley Please keep us updated about your good work!
July 18, 2015 09:47PM
I personally find this thread valuable, and it is also useful for someone who is interested in building a large build 3d printer, and the constraints of doing so.
July 21, 2015 10:41AM
http://imgur.com/a/ScPIV
So much for the idea that FDM is useless in large volumes...
