Best $500 3d printer? June 11, 2015 09:53PM |
Re: Best $500 3d printer? June 11, 2015 10:20PM |
Re: Best $500 3d printer? June 11, 2015 10:36PM |
I did see them, and I think that's really interesting. I'm just in a big debate between that and the MakerFarm i3v. It's layer height is 50 microns, which is pretty amazing. It's a tough decision. I really like how they use the v-slot linear rail.
Re: Best $500 3d printer? June 12, 2015 10:09AM |
Re: Best $500 3d printer? June 12, 2015 03:11PM |
Re: Best $500 3d printer? June 12, 2015 05:49PM |
It still uses a threaded rod and the computer can measure 50 microns when you try to print with it. Are you joking?Quote
thetazzbot
The wanhou is a better looking printer and it uses lead screws not threaded rod for the z axis. PS Anyone can claim 50 micron. Can you measure it?
Wanhou $429, much better looking, electronics and PS enclosed in its own case. Win!
Re: Best $500 3d printer? June 12, 2015 06:03PM |
Re: Best $500 3d printer? June 12, 2015 06:09PM |
Re: Best $500 3d printer? June 12, 2015 07:21PM |
Re: Best $500 3d printer? June 12, 2015 07:22PM |
Re: Best $500 3d printer? June 12, 2015 07:50PM |
Re: Best $500 3d printer? July 06, 2015 12:10PM |
fatesalign
thetazzbot
I really like those v rods on the makerfarm.
The replicator used to only be 375. I just dont understand how they could be so cheap.
Re: Best $500 3d printer? July 06, 2015 02:45PM |
Print an object. Quit printing half way through a layer. Measure the difference between the unfinished side vs the finished side. Or measure your first layer. Or measure finished part divide by the number of layers printed.Quote
thetazzbot
also, I was referring to "can you measure the output", i.e. hold a pair of digital calipers to a print. It's painfully difficult to [manually] measure something .05 mm
Re: Best $500 3d printer? July 06, 2015 04:18PM |
cdru
thetazzbot
In reality, it doesn't matter what incremental layer heights are. Are the sides as smooth and consistent as they can be? Is the overall dimensions what was designed? That's what the important thing are.
