Adding Fan for bed printing
Posted by scubi
June 16, 2015 08:06AM
Hi
Please can you tell me where do I can connect the Fan that cools your prints as you print on the Ramps 1.4. If i connect to the power supply, then the fan runs at 100% all the time. Where do you connect where the software controls the fan.
Thanks
Re: Adding Fan for bed printing
June 16, 2015 08:18AM
You can connect your fan on the D9 connectors. And you must configure your "configuration.h" file properly, then you can use the fan with M106 command.
Prusa i3 - e3d v5 - Gnu/Linux - Pronterface - Slic3r - Octoprint - Rpi - French
June 16, 2015 08:37AM
Thanks, is it near the extruder driver and does not have pins, need a pin adaptor to connect to it ?
Just making sure
June 16, 2015 02:55PM
The D9 connector should be the terminals between the heated bed and hotnend connector, and should be screw terminals, just like then others . . .
- Tim
