Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 21, 2015 07:53AM |
Re: Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 21, 2015 11:26AM |
Re: Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 21, 2015 11:43AM |
Re: Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 21, 2015 08:14PM |
Re: Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 22, 2015 03:08AM |
Re: Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 22, 2015 04:22AM |
o_lampe
I´d say 1 yellow to 5A, two yellow to 11A input. Same for black. Use ferrules everywhere to make safe clamping contacts.
You can also route one black and red to the servo-terminal block of the RAMPS. This way, you can overcome problems with the weak 5V regulator from the arduino mega.
-Olaf
Re: Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 22, 2015 04:47AM |
Re: Is it possible to Run PC and Prusa i3 Hephestos off same pc power supply June 22, 2015 04:50AM |
