Modifying PC ATX PSU June 21, 2015 04:01PM |
Re: Modifying PC ATX PSU June 21, 2015 08:22PM |
Re: Modifying PC ATX PSU June 21, 2015 11:10PM |
Re: Modifying PC ATX PSU June 22, 2015 02:55AM |
Re: Modifying PC ATX PSU June 22, 2015 04:57AM |
Re: Modifying PC ATX PSU June 23, 2015 01:23PM |
Unless you have a split rail power supply, in which case what you know for sure is wrong. Be sure to check the nameplate ratings, silk screen, etc for indication if the 12V rail may be split. If it is, keep the rails wires separate lest bad things happen.Quote
Downunder35m
I have dismantled and re-used alot of ATX power supplies and one thing I know for sure is that all 12V and 5V wires connect to the same point on the circuit board.
