I need to build a case for a project that will be bolted on a surface that will be heated.
I did my tests with a thermocouple and the hot surface stabalize at max 81C (wont go over).
Usually, run time is about 6 minutes : ramping the hot surface to 80C then goes down from there).
At other times, it could also run longer. (around 3-4 hours, goes to 80C and won't go any higher)
Of course, i'll be using ABS for this project..
I know that the melt point is around 220C but what about the softning point ?
I'd like to know if 80C to high and will the ABS soften and warp my case or i'm I OK ?
Thanks,
J-F
