Which extruder setup ? June 23, 2015 02:00AM |
Re: Which extruder setup ? June 23, 2015 11:54AM |
Re: Which extruder setup ? June 24, 2015 10:13PM |
Re: Which extruder setup ? June 25, 2015 02:28AM |
Re: Which extruder setup ? June 25, 2015 01:16PM |
TFinleyosu
Do you guys know if direct drive designs have issues with slippage or resolution? I'm curious is a direct drive design with a NEMA 17 will have enough torque (Ebay Example)
I need to customize the mount for my extruder and a direct drive would simplify the design considerably or I could find an off the shelf option.
My instincts are to avoid 3D printed gears in this area for reliabilty and accuracy, but if the Greg Wade's Geared extruder has a good reputation, I should take that into consideration.
Re: Which extruder setup ? June 25, 2015 03:54PM |
GRAYWOLF
TFinleyosu
As long as the feed in clean and the setting are ok, the bulldog and hexagon are a good combo.
(just go a bulldog lite+Hexagon AO+0.3 nozzle to work well.)
Re: Which extruder setup ? June 25, 2015 03:59PM |
AndrewBCN
The challenge in getting a reliable direct drive extruder is very exactly that of torque. You have to rely on a proper drive gear (the MK7 and the MK8 gears are popular choices) and a good stepper motor driven at or near its maximum rated current, meaning it will also get quite hot.
Greg's Wade's Geared Extruder has a sterling reputation because it avoids these issues. The 3D printed fishbone gears have very little or no play/backslash and at least in my case, have proven to be extremely reliable.
You have to experiment and try various extruder types and check the pros and cons of each type and how they suit your particular setup, there is no universal solution.
Re: Which extruder setup ? June 25, 2015 05:33PM |
Re: Which extruder setup ? June 27, 2015 01:21PM |
Re: Which extruder setup ? June 27, 2015 01:33PM |
Re: Which extruder setup ? June 27, 2015 01:49PM |
GRAYWOLF
TFinleyosu
Re: Which extruder setup ? June 27, 2015 01:59PM |
Re: Which extruder setup ? June 27, 2015 02:28PM |
Re: Which extruder setup ? June 27, 2015 03:03PM |
