New Delta Printer - Look Ma, no rails! June 25, 2015 12:48AM |
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 02:18AM |
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 02:44AM |
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 01:17PM |
AndrewBCN
Nice experimental design!
However, your video does not show how the wood poles are spring loaded and I wonder how you manage the Z-height of the effector, is that by simply compressing the springs that load the wood poles?
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 01:57PM |
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 05:51PM |
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 06:04PM |
JamesK
That is all sorts of crazy. I would never have guessed it would work. Congratulations!
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 10:34PM |
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 11:16PM |
Re: New Delta Printer - Look Ma, no rails! June 25, 2015 11:25PM |
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 01:17AM |
simspeed
I wonder what the life-cycle of the line will be at the effector wear points..?
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 01:20AM |
thetazzbot
Does the hot end really need to be centered
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 01:24AM |
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 01:28AM |
simspeed
The E3D Cyclops has the filament feed offset at right angles to the print nozzle. So yes that approach does work. Also the CEL-Robox printer feeds the filament 90° to the nozzle. Lay the Cyclops on its side where the Bowden tubes feed horizonal to the bed; drill and tap the nozzle 90° to the stock location and set it all on a lower stage effector plate. Should work well.
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 01:35AM |
simspeed
I'd be more inclined to use a base pivoting micro pulley machined out of Delrin or even aluminum. They make them pretty small.
[static.rcgroups.net]
I'd think maybe a little heavier line too.
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 01:45AM |
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 01:53AM |
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 02:08AM |
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 02:53AM |
Re: New Delta Printer - Look Ma, no rails! June 26, 2015 12:15PM |
o_lampe
I hope you/we can make up a version where these parts are printable.
o_lampe
I´m not sure, if I fully understood the principle, but if you´d print a tall part, the fishing line would wind up on the stepper shaft completely?
I thought about the growing "shaft diameter" if the fishing line builds up layer after layer on the shaft.
Would that cause a nonlinearity in z-movement?
Olaf
Re: New Delta Printer - Look Ma, no rails! June 27, 2015 02:56AM |
Re: New Delta Printer - Look Ma, no rails! June 27, 2015 11:19AM |
simspeed
Loss of resolution as the Z lengthens is a deal breaker I'm guessing.
Re: New Delta Printer - Look Ma, no rails! June 27, 2015 05:12PM |
Re: New Delta Printer - Look Ma, no rails! July 03, 2015 01:29AM |
Re: New Delta Printer - Look Ma, no rails! July 03, 2015 01:44AM |
Re: New Delta Printer - Look Ma, no rails! July 03, 2015 02:41AM |
Re: New Delta Printer - Look Ma, no rails! July 03, 2015 10:59AM |
Re: New Delta Printer - Look Ma, no rails! July 03, 2015 11:54AM |
tobben
How do you deal with line building up on your spools?
Re: New Delta Printer - Look Ma, no rails! July 03, 2015 12:23PM |
Re: New Delta Printer - Look Ma, no rails! July 03, 2015 02:50PM |
