Re: New Delta Printer - Look Ma, no rails! July 13, 2015 07:44PM |
Re: New Delta Printer - Look Ma, no rails! July 14, 2015 03:30AM |
Re: New Delta Printer - Look Ma, no rails! July 14, 2015 10:37AM |
o_lampe
I remember you have a ball shaped end on the tension post to the effector. There is some friction for sure?
Would you consider using a needle pin design centered in a dent of a hard plate?
-Olaf
Re: New Delta Printer - Look Ma, no rails! July 14, 2015 12:58PM |
Re: New Delta Printer - Look Ma, no rails! July 19, 2015 11:54AM |
Re: New Delta Printer - Look Ma, no rails! July 19, 2015 12:43PM |
Re: New Delta Printer - Look Ma, no rails! July 19, 2015 12:50PM |
echenlon
Actually this is a really really elegant solution! I really like it, I would love to try it out, maybe in a few weeks I can build a motion testing platform.
My only doubt is:
Why you say you loose resolution with longer lines? I can't catch that part of the deal. Also, rubber has a funny way to apply tension, if you use springs the tension will be more uniform. maybe that helps.
Re: New Delta Printer - Look Ma, no rails! July 20, 2015 01:53AM |
Re: New Delta Printer - Look Ma, no rails! July 20, 2015 07:51AM |
LoboCNC
echenlon
My only doubt is:
Thanks! Regarding resolution, in a Cartesian-type printer, the amount each motor has to move in order to move, say, 1mm is the same, independent of where you are in the workspace. In a non-Cartesian system like this, you have to solve non-linear equations to determine the motor positions from your XYZ coordinates. If you are at the top of the workspace, moving 1mm in the X direction might require Motor1 to move 150 steps. When you are at the bottom of the work space, with all the strings extended, moving 1mm might require Motor1 to only move 50 steps. As the 3 sets of strings become closer to parallel to each other, the number of steps becomes so coarse that you'll get significant errors in your print.
Regarding the springs, I agree - using metal springs will provide a more uniform tension. I started using silicone rubber tubing because I needed to experiment with lots of different spring lengths, and it's a lot easier to adjust the lengths with the tubing. I should go back and measure my rubber spring constant and replace them with metal springs. In my first version, the springs changed length quite a bit and this would be much more important. I the current design, though, the lengths remain more constant, so using more "linear" springs is not as important.
Re: New Delta Printer - Look Ma, no rails! July 20, 2015 12:53PM |
ekaggrat
super cool... What firmware are you using?
Re: New Delta Printer - Look Ma, no rails! July 21, 2015 04:06AM |
Re: New Delta Printer - Look Ma, no rails! July 21, 2015 07:57AM |
Re: New Delta Printer - Look Ma, no rails! July 21, 2015 04:17PM |
Re: New Delta Printer - Look Ma, no rails! July 22, 2015 10:23AM |
Re: New Delta Printer - Look Ma, no rails! July 23, 2015 02:52PM |
Re: New Delta Printer - Look Ma, no rails! July 23, 2015 07:59PM |
Re: New Delta Printer - Look Ma, no rails! July 24, 2015 07:30AM |
Re: New Delta Printer - Look Ma, no rails! July 24, 2015 04:48PM |
Re: New Delta Printer - Look Ma, no rails! July 24, 2015 09:19PM |
Re: New Delta Printer - Look Ma, no rails! July 26, 2015 04:21PM |
Re: New Delta Printer - Look Ma, no rails! July 26, 2015 06:30PM |
Re: New Delta Printer - Look Ma, no rails! September 10, 2015 08:38AM |
Re: New Delta Printer - Look Ma, no rails! October 05, 2015 11:24AM |
Re: New Delta Printer - Look Ma, no rails! October 05, 2015 12:44PM |
NEATman
I just saw this crazy motion simulator:
[www.youtube.com]
I know it is much more complexity with 8 winches, but I thought it may inspire more ideas.
Keith
Re: New Delta Printer - Look Ma, no rails! October 09, 2015 09:13PM |
Re: New Delta Printer - Look Ma, no rails! October 10, 2015 01:21AM |
Linkreincarnate
So I am working on a sort of inverted version of this. It shortens in the downward direction instead of upwards and has rubber bands pulling it upwards instead of pushing down.
It's still in the rough draft form so ignore some of the obvious problems in this design for now. I am going to work those out once I get the kinematics problem resolved.
Would these inverse kinematics work for my design if I multiplied the motion of the steppers by -1? What would I need to change here to adapt this modification of inverse kinematics in marlin to work with my machine? Any chance of getting someone to break this math down to me?
Re: New Delta Printer - Look Ma, no rails! October 10, 2015 01:02PM |
Re: New Delta Printer - Look Ma, no rails! October 10, 2015 05:53PM |
Re: New Delta Printer - Look Ma, no rails! October 10, 2015 06:07PM |
Linkreincarnate
Ok Thanks I kinda knew that but I've been putting off a redesign until I get it running as expected. Are there any rules about how they are constrained? I really want to keep the spools on the top and anchored to the bottom so I can put this in different sized frames.
Re: New Delta Printer - Look Ma, no rails! October 10, 2015 10:53PM |
