re-sticking bed heaters
Posted by Zedsquared
June 25, 2015 10:02AM
Hi Folks,
does anyone have any success story regarding a decent adhesive to re attach bed heat pads to borosilicate glass?
I have had one bad experience with a kapton flex PCB style heater, the double sided tape I used just wouldn't take for long and it would curl off after a few days.
This is despite a good cleaning with acetone of both surfaces before application and avoiding contamination throughout.
The original glue that came pre applied was great but I decided to get a bigger glass plate and then the woe started!
I now have one of those terracotta coloured silicone pads stuck nicely to the glass but, should I want to fit a heat spreader for instance, what would work?
I'm in the UK BTW.
Cheers,
Robin.
Re: re-sticking bed heaters
June 25, 2015 12:49PM
I suggest heat resistant double sided adhesive sheet by 3M, which is probably what came on your silicone heater in the first place. I don't know what grades 3M does, but this one [www.ebay.co.uk] says it is resistant to hot/cold cycles.
I have my silicone heater stuck on the bottom of an aluminium sheet to act as a bed support and heat spreader, and I clip my float glass beds on top of that. See [miscsolutions.wordpress.com].
Edited 2 time(s). Last edit at 06/26/2015 11:15AM by dc42.
June 26, 2015 10:59AM
3M 200MP sounds familiar, I remember trying to find it in tape form in the UK and failing, didn't think about sheets of it! Thanks for the link smiling smiley
Cheers,
Robin.
