Painters tape too good! Less adhesion? June 28, 2015 09:11PM |
Re: Painters tape too good! Less adhesion? June 28, 2015 10:19PM |
Re: Painters tape too good! Less adhesion? June 29, 2015 01:48AM |
Re: Painters tape too good! Less adhesion? June 29, 2015 04:06PM |
Epop
I call 'too good' when I destroy the part trying to get it off the printbed. You could be a little bit too close or extruding a little too much on your first layer... if you print without a raft etc. and scrape the side of your part with your fingernail and feel a lip/ledge/bump on the last layer it could be either at a glance.
But... tape is cheap, if thats the only issue you have if you get it wet with water it will come off your part. buy a contractors pack if you don't know a painter (4-5 full rolls of 2" blue painters tape(3M brand) for... I think ~$15, I haven't been through 1 yet) I will probably try 'bullfrog' i think it was... essentialy 'green' painters tape(its a little less sticky) next time...
I print on paintertape at 45°C and when it cools down by 10-15°C, I can peel it off much easier.
-Olaf
