Solved : Layer Number and Time Remaining on Graphical LCD July 15, 2015 04:59PM |
#!/usr/bin/perl -i use strict; use warnings; use utf8; #variables for layer count my $layerCount = 0; my $linesCount = 0; my $file_name = ""; my $filamentmm = 0; my $G1zCount = 0; my $SkipLayers = 0; my $TrackType = 0; my @all_nums; $file_name = $ARGV[0]; print "\n"; print "File Name ".$file_name."\n"; print "Reading file loop - gathering data\n"; $^I = '.bak'; while ( <> ) { if (index($_, ';newlayerhere') == 0) { # find the lines that contain the New Layer flag comment $layerCount++; } if (index($_, 'G1 Z') == 0) { # looks for the ;SLC flag comment and resets the line counter to 0 ( SLC used to count only print lines ) $G1zCount++; } if (index($_, ';SLC') == 0) { # looks for the ;SLC flag comment and resets the line counter to 0 ( SLC used to count only print lines ) $linesCount=0; $SkipLayers=$G1zCount; } if (index($_, 'G1 X') == 0) { # count the print lines that contain 'G1 X' $linesCount++; } if (index($_, ';TrackType=Filament') == 0) { $TrackType=1; } if (index($_, ';TrackType=PrintLines') == 0) { $TrackType=2; } if (/^(;\s+filament\s+used\s+=\s.*\((\d+(?:\.\d+)?)cm3)\)/) { # get the filament length listed in the gCode file (mm) -- # print $_; contains the line read from the file @all_nums = $_ =~ /(\d+)/g; # (123, 456, 789) so creates an array of the numbers in the line print; } else { print; } } print "Layer Count = ".$layerCount."\n"; print "Lines Count = ".$linesCount."\n"; print "Skip pre-Layers = ".$SkipLayers."\n"; print "filamentmm = ".$all_nums[0]."\n"; use File::Basename; use File::Copy; print "Copying gCode to temp file\n"; my($file, $dir, $ext) = fileparse($file_name); # extract the dir from the original file name and use for same location of temp file my $tempGfile = $dir . "TempScriptFile.gcode"; copy($file_name, $tempGfile); #list the file names being used print "Temp. File = ".$tempGfile."\n"; print "Orig. File = ".$file_name."\n"; #open the target file open(my $fhS, '>', $file_name); if (open(my $fh, '<:encoding(UTF-8)', $tempGfile)) { printf $fhS "; layer count = %d\n", $layerCount; printf $fhS "; lines count = %d\n", $linesCount; printf $fhS "; PreLayers = %d\n", $SkipLayers; printf $fhS "; filament = %d\n", $all_nums[0]; printf $fhS "; tracktype = %d\n", $TrackType; while (my $row = <$fh> ) { chomp $row; if (index($row, ';newlayerhere') == -1) { print $fhS "$row\n"; } } } print "Operation completed\n";
;TrackType=Filament ; set =Filament or =PrintLines ;SLC
;newlayerhere
22:09:59.590 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load "C:\Users\User\AppData\Local\RepetierHost\slic3r.ini" --print-center 125,125 -o "C:\Users\User\AppData\Local\RepetierHost\composition.gcode" "C:\Users\User\AppData\Local\RepetierHost\composition.amf" 22:10:01.074 : => Processing triangulated mesh 22:10:01.204 : => Generating perimeters 22:10:01.536 : => Preparing infill 22:10:01.986 : => Infilling layers 22:10:02.191 : => Generating skirt 22:10:02.199 : => Exporting G-code to C:\Users\User\AppData\Local\RepetierHost\composition.gcode 22:10:02.978 : => Running post-processing scripts 22:10:03.320 : File Name C:\Users\User\AppData\Local\RepetierHost\composition.gcode 22:10:03.320 : Reading file loop - gathering data 22:10:03.320 : Layer Count = 75 22:10:03.320 : Lines Count = 19306 22:10:03.320 : Skip pre-Layers = 1 22:10:03.320 : filamentmm = 671 22:10:03.320 : Copying gCode to temp file 22:10:03.320 : Temp. File = C:\Users\User\AppData\Local\RepetierHost\TempScriptFile.gcode 22:10:03.320 : Orig. File = C:\Users\User\AppData\Local\RepetierHost\composition.gcode 22:10:03.320 : Operation completed 22:10:03.330 : Done. Process took 0 minutes and 2.256 seconds 22:10:03.330 : Filament required: 671.5mm (1.6cm3)
; layer count = 75 ; lines count = 19306 ; PreLayers = 1 ; filament = 671 ; tracktype = 1 ; generated by Slic3r 1.2.9 on 2015-07-15 at 22:10:02 ; external perimeters extrusion width = 0.40mm ; perimeters extrusion width = 0.48mm ; infill extrusion width = 0.48mm ; solid infill extrusion width = 0.48mm ; top infill extrusion width = 0.48mm M107 M190 S15 ; set bed temperature M104 S15 ; set temperature G28 ; home all axes G1 Z6 F5000 ; lift nozzle M92 E515 G1 Y20 F5000 ;TrackType=Filament ; set =Filament or =PrintLines ;SLC M109 S15 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 G1 E-1.00000 F1800.00000 G92 E0 G1 Z0.300 F10200.000 G1 X114.868 Y116.678 F10200.000 G1 E1.00000 F1800.00000 G1 X115.412 Y116.197 E1.04850 F1080.000 G1 X115.932 Y115.813 E1.09171
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// ==> my note : uncomment this line to make the graphical LCD show the Layer Count and Estimated Time Remaining instead of the XYZ positions #define ShowLayerCountAndEstTime
extern float add_homing[3];
// my note : added global variables for tracking Layers and Print Lines extern int LayerCountTotal; extern int LayerCountCurrent; extern float FilamentCurrent; extern float PrintLinesTotal; extern float PrintLinesCurrent; extern float FilamentTotal; extern int TrackType;
float zprobe_zoffset;
// my note : added variables for tracking Layers and Print Lines int LayerCountTotal; int LayerCountCurrent; float FilamentCurrent; float PrintLinesTotal; float PrintLinesCurrent; float FilamentTotal; int LayersToIgnore; bool CountLinesAndLayers = false; int TrackType;
switch((int)code_value()) { case 0: // G0 -> G1 case 1: // G1 if(Stopped == false) {
switch((int)code_value()) { case 0: // G0 -> G1 case 1: // G1 // my note : increase the PrintLines count by 1 to track current Printline Count and calculate the Estimated Time Remaining PrintLinesCurrent++; if(code_seen('E')){ get_coordinates(); float echange=destination[E_AXIS]-current_position[E_AXIS]; FilamentCurrent = FilamentCurrent + echange; } // // my note : add code to increase the LCD layer count by 1 if the gCode contains a new Z axis instruction if(code_seen('Z')) LayerCountCurrent++; if(LayersToIgnore > 0){ // ignore the layer count before the ;SLC was detected ( if it exists in the gcode file ) LayersToIgnore--; LayerCountCurrent = 0; PrintLinesCurrent = 0; FilamentCurrent = 0; } if(Stopped == false) {
case 23: starpos = (strchr(strchr_pointer + 4,'*')); if(starpos!=NULL) *(starpos)='\0'; card.openFile(strchr_pointer + 4,true); break; case 24: card.startFileprint(); starttime=millis(); break;
case 23: //M23 - Select file starpos = (strchr(strchr_pointer + 4,'*')); if(starpos!=NULL) *(starpos)='\0'; // my note : add code to count the Z axis commands ( layers ) in the file and the G1 print lines in the file #ifdef SDSUPPORT #ifdef ShowLayerCountAndEstTime CountLinesAndLayers = true; #endif //layer counter #endif //SDSUPPORT if(CountLinesAndLayers != true) card.openFile(strchr_pointer + 4,true); //this is in M23 - Select file // name, read, replace break; case 24: //M24 - Start SD print // my note : SD card print starts here LayerCountCurrent = 0; card.startFileprint(); starttime=millis(); break;
else { SERIAL_ECHO_START; SERIAL_ECHOPGM(MSG_UNKNOWN_COMMAND); SERIAL_ECHO(cmdbuffer[bufindr]); SERIAL_ECHOLNPGM("\""); } ClearToSend(); } void FlushSerialRequestResend()
else { SERIAL_ECHO_START; SERIAL_ECHOPGM(MSG_UNKNOWN_COMMAND); SERIAL_ECHO(cmdbuffer[bufindr]); SERIAL_ECHOLNPGM("\""); } ClearToSend(); if(CountLinesAndLayers == true){ // read the SD file and count the lines and layers CountLinesAndLayers = false; PrintLinesTotal = 0; LayerCountTotal = 0; FilamentTotal = 0; TrackType = 0; card.openFile(strchr_pointer + 4,true); chPos = 0; // pointer for position of next char in buffer array int ReadingLineNumber = 1; while(!card.eof() && ReadingLineNumber < 6){ int16_t n=card.get(); serial_char = (char)n; if(chPos < 59) SDbuffer[chPos] = serial_char; chPos++; if(serial_char == '\n'){ // if the character read from the SD card is a line ending /* first 5 lines of the gCode file ; layer count = 75 ; lines count = 19306 ; PreLayers = 1 ; filament = 671 ; tracktype = 1 // 1 = Filament, 2 = PrintLines */ if(ReadingLineNumber == 1){ // read the layer count if ( strstr(SDbuffer, "; layer count =") ) LayerCountTotal = atoi(&SDbuffer[15]); } if(ReadingLineNumber == 2){ // read the lines count if ( strstr(SDbuffer, "; lines count =") ) PrintLinesTotal = atof(&SDbuffer[15]); } if(ReadingLineNumber == 3){ // read the layers to skip in setup before print starts if ( strstr(SDbuffer, "; PreLayers =") ) LayersToIgnore = atoi(&SDbuffer[13]); } if(ReadingLineNumber == 4){ // read the filament length if ( strstr(SDbuffer, "; filament =") ) FilamentTotal = atof(&SDbuffer[12]); } if(ReadingLineNumber == 5){ // read the tracking type if ( strstr(SDbuffer, "; tracktype =") ) TrackType = atoi(&SDbuffer[13]); } chPos = 0; // reset the position for the next character in the buffer. Set to 0 = empty the buffer. ReadingLineNumber++; } } card.closefile(); delay(200); card.openFile(strchr_pointer + 4,true); //this is in M23 - Select file } // end of : if(CountLinesAndLayers = true) } // end of : if(code_seen('M')) void FlushSerialRequestResend()
// Fan u8g.setFont(FONT_STATUSMENU); u8g.setPrintPos(104,27); #if defined(FAN_PIN) && FAN_PIN > -1 u8g.print(itostr3(int((fanSpeed*100)/256 + 1))); u8g.print("%"); #else u8g.print("---"); #endif // X, Y, Z-Coordinates - make white on black panel u8g.setFont(FONT_STATUSMENU); u8g.drawBox(0,29,128,10); u8g.setColorIndex(0); // white on black u8g.setPrintPos(2,37); // move to position to print the 'X' u8g.print("X"); // print the 'X' character u8g.drawPixel(8,33); // top dot of the colon u8g.drawPixel(8,35); // bottom dot of the colon u8g.setPrintPos(10,37); // move to position to print the value u8g.print(ftostr31ns(current_position[X_AXIS])); // print the X axis value u8g.setPrintPos(43,37); // move to position to print the 'Y' lcd_printPGM(PSTR("Y")); u8g.drawPixel(49,33); u8g.drawPixel(49,35); u8g.setPrintPos(51,37); u8g.print(ftostr31ns(current_position[Y_AXIS])); u8g.setPrintPos(83,37); // move to position to print the 'Z' u8g.print("Z"); u8g.drawPixel(89,33); u8g.drawPixel(89,35); u8g.setPrintPos(91,37); u8g.print(ftostr31(current_position[Z_AXIS])); u8g.setColorIndex(1); // reset the display colors back to black on white
// Fan u8g.setFont(FONT_STATUSMENU); u8g.setPrintPos(104,27); #if defined(FAN_PIN) && FAN_PIN > -1 u8g.print(itostr3(int((fanSpeed*100)/256 + 1))); u8g.print("%"); #else u8g.print("---"); #endif // X, Y, Z-Coordinates - make white on black panel u8g.setFont(FONT_STATUSMENU); u8g.drawBox(0,29,128,10); u8g.setColorIndex(0); // white on black #ifdef ShowLayerCountAndEstTime // Check if the config option to show the layer count ( instead of the XYZ positions ) is enabled char LCDline1[20]; // create the LCD line array with the data to be displayed LCDline1[0] = '\0'; // clear the line to be displayed if(PrintLinesTotal > 0 && LayerCountTotal > 0){ int DHRP = 0; // integer for estimated hours remaining int DMRP = 0; // integer for estimated minutes remaining if(PrintLinesCurrent >= 10){ // start calcs after the first 10 lines have been printed long CurrentPrintTime=0; CurrentPrintTime = millis() - starttime; // calc the milliseconds that the job has been running so far float EMR = 0; int SRP = 0; int MRP = 0; if(TrackType == 2){ // track the time remaining based on the PrintLines // calc Est. Time Remaining using number of print lines done vs remaining EMR = (CurrentPrintTime / PrintLinesCurrent) * (PrintLinesTotal - PrintLinesCurrent); // calc the estimated millis remaining SRP = trunc(EMR / 1000); // convert remaining millis to seconds remaining for print MRP = trunc(SRP / 60); // convert seconds to minutes remaining for print if(MRP < 1) MRP = 1; // keep the value at 1 minute for the last few layers when the actual value < 1 minute if(PrintLinesTotal == PrintLinesCurrent) MRP = 0; // switch to zero when all lines printed } if(TrackType == 1){ // track the time remaining based on the Filament // calc Est. Time Remaining using filament required vs filament used EMR = (CurrentPrintTime / FilamentCurrent) * (FilamentTotal - FilamentCurrent); // calc the estimated millis remaining SRP = trunc(EMR / 1000); // convert remaining millis to seconds remaining for print MRP = trunc(SRP / 60); // convert seconds to minutes remaining for print if(MRP < 1) MRP = 1; // keep the value at 1 minute for the last few layers when the actual value < 1 minute if(FilamentTotal == FilamentCurrent) MRP = 0; // switch to zero when all lines printed } DHRP = trunc(MRP / 60); // how many hours in MRP remaining for print DMRP = MRP - (DHRP * 60); // calc remaining minutes after subtracting DHRP hours } sprintf (LCDline1, "L%03d/%03d e%02d:%02d", LayerCountCurrent, LayerCountTotal, DHRP, DMRP); u8g.setPrintPos(2,37); u8g.print(LCDline1); } #endif if(PrintLinesTotal == 0 || LayerCountTotal == 0){ // otherwise display the standard XYZ positions u8g.setPrintPos(2,37); // move to position to print the 'X' u8g.print("X"); // print the 'X' character u8g.drawPixel(8,33); // top dot of the colon u8g.drawPixel(8,35); // bottom dot of the colon u8g.setPrintPos(10,37); // move to position to print the value u8g.print(ftostr31ns(current_position[X_AXIS])); // print the X axis value u8g.setPrintPos(43,37); // move to position to print the 'Y' lcd_printPGM(PSTR("Y")); u8g.drawPixel(49,33); u8g.drawPixel(49,35); u8g.setPrintPos(51,37); u8g.print(ftostr31ns(current_position[Y_AXIS])); u8g.setPrintPos(83,37); // move to position to print the 'Z' u8g.print("Z"); u8g.drawPixel(89,33); u8g.drawPixel(89,35); u8g.setPrintPos(91,37); u8g.print(ftostr31(current_position[Z_AXIS])); } u8g.setColorIndex(1); // reset the display colors back to black on white
Re: Solved : Layer Number and Time Remaining on Graphical LCD July 16, 2015 02:42AM |
Layer ETR LCDT Total 1 1:41 :01 1:42 5 1:25 :04 1:29 10 1:50 :06 1:56 23 2:27 :12 2:39 45 2:39 :22 3:01 55 2:33 :28 3:01 65 2:25 :33 2:58 83 2:08 :42 2:50 90 2:01 :46 2:47 106 1:45 :55 2:45 117 1:35 1:00 2:35 126 1:27 1:05 2:32 148 1:08 1:17 2:25 162 :56 1:25 2:21 213 :17 1:53 2:10
Layer ETR LCDT Total 5 4:29 :04 4:33 10 3:01 :06 3:07 15 2:36 :07 2:43 20 2:23 :09 2:32 23 2:18 :11 2:29 37 2:04 :18 2:22 48 1:56 :24 2:20 55 1:52 :27 2:19 66 1:46 :33 2:19 109 1:22 :55 2:17 132 1:08 1:08 2:16 151 :56 1:18 2:14 179 :37 1:33 2:10 204 :20 1:47 2:07 226 :04 2:00 2:04 233 :00 2:05 2:05
Re: Solved : Layer Number and Time Remaining on Graphical LCD July 17, 2015 03:53PM |
davr commented on Sep 29, 2013 Ok, I now have a small program that will produce time estimates that should match 100% the actual print time
Layer ETR remaining (m) time elapsed (m) 1 21 0 5 18 3 17 15 6 56 3 18 62 1 20 66 0 21 75 0 22
#!/usr/bin/perl -i use strict; use warnings; use utf8; use File::Basename; #variables for layer count my $layerCount = 0; my $linesCount = 0; my $file_name = ""; my $filamentmm = 0; my $G1zCount = 0; my $SkipLayers = 0; my $TrackType = 0; my @all_nums; my @all_numsT; $file_name = $ARGV[0]; my($file, $dir, $ext) = fileparse($file_name); # extract the dir from the original file name and use for same location of temp file #create the batch file open(my $bf1, '>', $dir."calc1.bat"); printf $bf1 "del ".$dir."calc1.txt\n"; printf $bf1 $dir."calc.exe ".$dir."composition.gcode > ".$dir."calc1.txt\n"; printf $bf1 "del ".$dir."calcTemp.txt\n"; printf $bf1 "exit\n"; close $bf1; #create a temp flag file that the batch file will delete after it has completed open($bf1, '>', $dir."calcTemp.txt"); printf $bf1 "This is a Flag File for deleting by the bat file when it is completed\n"; close $bf1; #run the batch file system("start ".$dir."calc1.bat"); # run the batch file #wait for the batch file to complete. Completes when it deletes the flag file. sleep 1 while -e $dir."calcTemp.txt"; #read the time from the calc1.txt output file #calc1.txt contents example : #Processed 19697 Gcodes and 216 Mcodes. 19562 blocks #Total time: 00:21:32 s if (open(my $fh, '<:encoding(UTF-8)', $dir."calc1.txt")) { while (my $row = <$fh> ) { chomp $row; if (index($row, 'Total time:') == 0) { # looks for the Total Time line in the calc1.txt file @all_numsT = $row =~ /(\d+)/g; # (123, 456, 789) so creates an array of the numbers in the line } } } print "Located Total Time H : ".$all_numsT[0]."\n"; print "Located Total Time M : ".$all_numsT[1]."\n"; print "Located Total Time S : ".$all_numsT[2]."\n"; my $TotalETP = 0; $TotalETP = ($all_numsT[0] * 60 * 60) + ($all_numsT[1] * 60) + ($all_numsT[2]); print "ETP Seconds = ".$TotalETP."\n"; print "\n"; print "File Name ".$file_name."\n"; print "Reading file loop - gathering data\n"; $^I = '.bak'; while (<> ) { if (index($_, ';newlayerhere') == 0) { # find the lines that contain the New Layer flag comment $layerCount++; } if (index($_, 'G1 Z') == 0) { # looks for the ;SLC flag comment and resets the line counter to 0 ( SLC used to count only print lines ) $G1zCount++; } if (index($_, ';SLC') == 0) { # looks for the ;SLC flag comment and resets the line counter to 0 ( SLC used to count only print lines ) $linesCount=0; $SkipLayers=$G1zCount; } if (index($_, 'G1 X') == 0) { # count the print lines that contain 'G1 X' $linesCount++; } if (index($_, ';TrackType=Filament') == 0) { $TrackType=1; } if (index($_, ';TrackType=PrintLines') == 0) { $TrackType=2; } if (index($_, ';TrackType=ETP') == 0) { $TrackType=3; } if (/^(;\s+filament\s+used\s+=\s.*\((\d+(?:\.\d+)?)cm3)\)/) { # get the filament length listed in the gCode file (mm) -- # print $_; contains the line read from the file @all_nums = $_ =~ /(\d+)/g; # (123, 456, 789) so creates an array of the numbers in the line print; } else { print; } } print "Layer Count = ".$layerCount."\n"; print "Lines Count = ".$linesCount."\n"; print "Skip pre-Layers = ".$SkipLayers."\n"; print "filamentmm = ".$all_nums[0]."\n"; use File::Basename; use File::Copy; print "Copying gCode to temp file\n"; #my($file, $dir, $ext) = fileparse($file_name); # extract the dir from the original file name and use for same location of temp file my $tempGfile = $dir . "TempScriptFile.gcode"; copy($file_name, $tempGfile); #list the file names being used print "Temp. File = ".$tempGfile."\n"; print "Orig. File = ".$file_name."\n"; #open the target file open(my $fhS, '>', $file_name); if (open(my $fh, '<:encoding(UTF-8)', $tempGfile)) { printf $fhS "; layer count = %d\n", $layerCount; printf $fhS "; lines count = %d\n", $linesCount; printf $fhS "; PreLayers = %d\n", $SkipLayers; printf $fhS "; filament = %d\n", $all_nums[0]; printf $fhS "; ETP = %d\n", $TotalETP; printf $fhS "; tracktype = %d\n", $TrackType; while (my $row = <$fh> ) { chomp $row; if (index($row, ';newlayerhere') == -1) { print $fhS "$row\n"; } } } print "Operation completed\n";
;TrackType=ETP ; set =Filament or =PrintLines or=ETP ;SLC
;newlayerhere
21:39:16.382 : Starting object analyser ... 21:39:16.469 : Object is manifold. 21:39:16.489 : Analysing finished. 21:39:18.257 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load "C:\Users\User\AppData\Local\RepetierHost\slic3r.ini" --print-center 125,125 -o "C:\Users\User\AppData\Local\RepetierHost\composition.gcode" "C:\Users\User\AppData\Local\RepetierHost\composition.amf" 21:39:19.854 : => Processing triangulated mesh 21:39:19.967 : => Generating perimeters 21:39:20.319 : => Preparing infill 21:39:20.774 : => Infilling layers 21:39:21.005 : => Generating skirt 21:39:21.013 : => Exporting G-code to C:\Users\User\AppData\Local\RepetierHost\composition.gcode 21:39:21.847 : => Running post-processing scripts 21:39:23.785 : Located Total Time H : 00 21:39:23.785 : Located Total Time M : 21 21:39:23.785 : Located Total Time S : 32 21:39:23.785 : ETP Seconds = 1292 21:39:23.785 : File Name C:\Users\User\AppData\Local\RepetierHost\composition.gcode 21:39:23.785 : Reading file loop - gathering data 21:39:23.785 : Layer Count = 75 21:39:23.785 : Lines Count = 19306 21:39:23.785 : Skip pre-Layers = 1 21:39:23.785 : filamentmm = 671 21:39:23.785 : Copying gCode to temp file 21:39:23.785 : Temp. File = C:\Users\User\AppData\Local\RepetierHost\TempScriptFile.gcode 21:39:23.786 : Orig. File = C:\Users\User\AppData\Local\RepetierHost\composition.gcode 21:39:23.786 : Operation completed 21:39:23.792 : Done. Process took 0 minutes and 3.952 seconds 21:39:23.793 : Filament required: 671.5mm (1.6cm3)
; layer count = 75 ; lines count = 19306 ; PreLayers = 1 ; filament = 671 ; ETP = 1292 ; tracktype = 3 ; generated by Slic3r 1.2.9 on 2015-07-17 at 21:39:21 ; external perimeters extrusion width = 0.40mm ; perimeters extrusion width = 0.48mm ; infill extrusion width = 0.48mm ; solid infill extrusion width = 0.48mm ; top infill extrusion width = 0.48mm M107 M190 S85 ; set bed temperature M104 S265 ; set temperature G28 ; home all axes G1 Z6 F5000 ; lift nozzle M92 E515 G1 Y20 F5000 ;TrackType=ETP ; set =Filament or =PrintLines or=ETP ;SLC M109 S265 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 G1 E-1.00000 F1800.00000 G92 E0 G1 Z0.300 F10200.000 G1 X114.868 Y116.678 F10200.000
// my note : added global variables for tracking Layers and Print Lines extern int LayerCountTotal; extern int LayerCountCurrent; extern float FilamentCurrent; extern float PrintLinesTotal; extern float PrintLinesCurrent; extern float FilamentTotal; extern int TrackType; extern long TrackTimeStart; extern long ETPtotal;
// my note : added variables for tracking Layers and Print Lines int LayerCountTotal; int LayerCountCurrent; float FilamentCurrent; float PrintLinesTotal; float PrintLinesCurrent; float FilamentTotal; int LayersToIgnore; bool CountLinesAndLayers = false; int TrackType; long TrackTimeStart; long ETPtotal;
switch((int)code_value()) { case 0: // G0 -> G1 case 1: // G1 // my note : increase the PrintLines count by 1 to track current Printline Count and calculate the Estimated Time Remaining PrintLinesCurrent++; if(code_seen('F')){ // start the timer when the filament is first moved if(TrackTimeStart <= 0){ TrackTimeStart = millis(); } } if(code_seen('E')){ get_coordinates(); float echange=destination[E_AXIS]-current_position[E_AXIS]; FilamentCurrent = FilamentCurrent + echange; } // // my note : add code to increase the LCD layer count by 1 if the gCode contains a new Z axis instruction if(code_seen('Z')) LayerCountCurrent++; if(LayersToIgnore > 0){ // ignore the layer count before the ;SLC was detected ( if it exists in the gcode file ) LayersToIgnore--; LayerCountCurrent = 0; PrintLinesCurrent = 0; FilamentCurrent = 0; } if(Stopped == false) {
else { SERIAL_ECHO_START; SERIAL_ECHOPGM(MSG_UNKNOWN_COMMAND); SERIAL_ECHO(cmdbuffer[bufindr]); SERIAL_ECHOLNPGM("\""); } ClearToSend(); if(CountLinesAndLayers == true){ // read the SD file and count the lines and layers CountLinesAndLayers = false; PrintLinesTotal = 0; LayerCountTotal = 0; FilamentTotal = 0; TrackType = 0; TrackTimeStart = 0; ETPtotal = 0; card.openFile(strchr_pointer + 4,true); chPos = 0; // pointer for position of next char in buffer array int ReadingLineNumber = 1; while(!card.eof() && ReadingLineNumber < 10){ int16_t n=card.get(); serial_char = (char)n; if(chPos < 59) SDbuffer[chPos] = serial_char; chPos++; if(serial_char == '\n'){ // if the character read from the SD card is a line ending /* first 5 lines of the gCode file ; layer count = 75 ; lines count = 19306 ; PreLayers = 1 ; filament = 671 ; tracktype = 1 // 1 = Filament, 2 = PrintLines, 3 = ETP */ if(ReadingLineNumber == 1){ // read the layer count if ( strstr(SDbuffer, "; layer count =") ){ LayerCountTotal = atoi(&SDbuffer[15]); } } if(ReadingLineNumber == 2){ // read the lines count if ( strstr(SDbuffer, "; lines count =") ){ PrintLinesTotal = atof(&SDbuffer[15]); } } if(ReadingLineNumber == 3){ // read the layers to skip in setup before print starts if ( strstr(SDbuffer, "; PreLayers =") ){ LayersToIgnore = atoi(&SDbuffer[13]); } } if(ReadingLineNumber == 4){ // read the filament length if ( strstr(SDbuffer, "; filament =") ){ FilamentTotal = atof(&SDbuffer[12]); } } if(ReadingLineNumber == 5){ // read the ETP time in seconds if ( strstr(SDbuffer, "; ETP =") ){ ETPtotal = atoi(&SDbuffer[7]); } } if(ReadingLineNumber == 6){ // read the tracking type if ( strstr(SDbuffer, "; tracktype =") ){ TrackType = atoi(&SDbuffer[13]); } } chPos = 0; // reset the position for the next character in the buffer. Set to 0 = empty the buffer. ReadingLineNumber++; } } card.closefile(); delay(200); card.openFile(strchr_pointer + 4,true); //this is in M23 - Select file } // end of : if(CountLinesAndLayers = true) } // end of : if(code_seen('M')) void FlushSerialRequestResend()
// Fan u8g.setFont(FONT_STATUSMENU); u8g.setPrintPos(104,27); #if defined(FAN_PIN) && FAN_PIN > -1 u8g.print(itostr3(int((fanSpeed*100)/256 + 1))); u8g.print("%"); #else u8g.print("---"); #endif // X, Y, Z-Coordinates - make white on black panel u8g.setFont(FONT_STATUSMENU); u8g.drawBox(0,29,128,10); u8g.setColorIndex(0); // white on black #ifdef ShowLayerCountAndEstTime // Check if the config option to show the layer count ( instead of the XYZ positions ) is enabled char LCDline1[20]; // create the LCD line array with the data to be displayed LCDline1[0] = '\0'; // clear the line to be displayed if(PrintLinesTotal > 0 && LayerCountTotal > 0){ int DHRP = 0; // integer for estimated hours remaining int DMRP = 0; // integer for estimated minutes remaining if(PrintLinesCurrent >= 10){ // start calcs after the first 10 lines have been printed long CurrentPrintTime=0; CurrentPrintTime = millis() - TrackTimeStart; // calc the milliseconds that the job has been running so far long EMR = 0; int SRP = 0; int MRP = 0; if(TrackType == 3){ // track the time remaining based on the ETP seconds SRP = ETPtotal - (CurrentPrintTime / 1000); // calc the seconds remaining MRP = trunc(SRP / 60); // convert seconds to minutes remaining for print if(MRP < 0) MRP = 0; // keep the value at 1 minute for the last few layers when the actual value < 1 minute } if(TrackType == 1){ // track the time remaining based on the Filament // calc Est. Time Remaining using filament required vs filament used EMR = (CurrentPrintTime / FilamentCurrent) * (FilamentTotal - FilamentCurrent); // calc the estimated millis remaining SRP = trunc(EMR / 1000); // convert remaining millis to seconds remaining for print MRP = trunc(SRP / 60); // convert seconds to minutes remaining for print if(MRP < 1) MRP = 1; // keep the value at 1 minute for the last few layers when the actual value < 1 minute if(FilamentTotal == FilamentCurrent) MRP = 0; // switch to zero when all lines printed } if(TrackType == 2){ // track the time remaining based on the PrintLines // calc Est. Time Remaining using number of print lines done vs remaining EMR = (CurrentPrintTime / PrintLinesCurrent) * (PrintLinesTotal - PrintLinesCurrent); // calc the estimated millis remaining SRP = trunc(EMR / 1000); // convert remaining millis to seconds remaining for print MRP = trunc(SRP / 60); // convert seconds to minutes remaining for print if(MRP < 1) MRP = 1; // keep the value at 1 minute for the last few layers when the actual value < 1 minute if(PrintLinesTotal == PrintLinesCurrent) MRP = 0; // switch to zero when all lines printed } DHRP = trunc(MRP / 60); // how many hours in MRP remaining for print DMRP = MRP - (DHRP * 60); // calc remaining minutes after subtracting DHRP hours DHRP = trunc(MRP / 60); // how many hours in MRP remaining for print DMRP = MRP - (DHRP * 60); // calc remaining minutes after subtracting DHRP hours } sprintf (LCDline1, "L%03d/%03d e%02d:%02d", LayerCountCurrent, LayerCountTotal, DHRP, DMRP); u8g.setPrintPos(2,37); u8g.print(LCDline1); } #endif if(PrintLinesTotal == 0 || LayerCountTotal == 0){ // otherwise display the standard XYZ positions u8g.setPrintPos(2,37); // move to position to print the 'X' u8g.print("X"); // print the 'X' character u8g.drawPixel(8,33); // top dot of the colon u8g.drawPixel(8,35); // bottom dot of the colon u8g.setPrintPos(10,37); // move to position to print the value u8g.print(ftostr31ns(current_position[X_AXIS])); // print the X axis value u8g.setPrintPos(43,37); // move to position to print the 'Y' lcd_printPGM(PSTR("Y")); u8g.drawPixel(49,33); u8g.drawPixel(49,35); u8g.setPrintPos(51,37); u8g.print(ftostr31ns(current_position[Y_AXIS])); u8g.setPrintPos(83,37); // move to position to print the 'Z' u8g.print("Z"); u8g.drawPixel(89,33); u8g.drawPixel(89,35); u8g.setPrintPos(91,37); u8g.print(ftostr31(current_position[Z_AXIS])); } u8g.setColorIndex(1); // reset the display colors back to black on white
