Build your own 3d printer class July 20, 2015 03:20PM |
Re: Build your own 3d printer class July 20, 2015 03:27PM |
thetazzbot
Class would involve a beginner's level kit (a cartesian printer, aka mendel 90 or prusa i3 varation); or a corexy using Smartrap Core "box" printer.
Re: Build your own 3d printer class July 20, 2015 04:05PM |
Re: Build your own 3d printer class July 20, 2015 04:29PM |
dc42
Nice idea!
thetazzbot
What have you got against deltas? I think the Fisher delta could be a good basis for such a course, once RepRapPro have improved the assembly instructions. With a delta you are mostly building the same thing 3 times, so there is less of a learning curve and more chance of getting the build finished in a day..
Re: Build your own 3d printer class July 20, 2015 04:31PM |
the_digital_dentist
I think it would be difficult to have most people build a printer during a one day class, especially if they're building different kits. For most, just tuning and getting it printing reasonably well in one day would be a challenge, even with knowledgeable assistance.
I'd go for a much longer class to get machines built, or have people build at home as complete as possible then bring them in for a get-it-working session along with all the explanations about software, etc.
Re: Build your own 3d printer class July 20, 2015 04:47PM |
Re: Build your own 3d printer class July 20, 2015 04:58PM |
thetazzbot
Nothing against Deltas, but they are not a beginner's level printer. That would be in the Advanced Class
Re: Build your own 3d printer class July 20, 2015 06:50PM |
Re: Build your own 3d printer class July 21, 2015 12:50AM |
Kurzaa
I would think it might be better to start with an introduction to 3D printing rather than jumping right into the build. Day one starts with downloading a pre-determined model from thingiverse and loading it into some design software to customize it. Then move onto validating the model and covering slicing options before moving onto printer designs (cartisian, coreXY, delta, stl,etc...) as well as the calibration process, filaments, and maintenance. The class ends with participants purchasing kits and scheduling a follow-up course to build one of 2-3 different printer designs (each with its own build day).
Building a printer is not that hard, getting it to work well and then creating objects to actually print might be more important aspects to cover before getting your feet wet. Just my two cents.
Re: Build your own 3d printer class July 21, 2015 01:18AM |
Re: Build your own 3d printer class July 21, 2015 10:42AM |
dc42
Nice idea!
thetazzbot
o_lampe
Kurzaa
Usually a good idea to start with the basics, but the participants would sure like to print their model and take it home as a "trophy".
Also without knowing what 3D printing is all about, the config of a slicer would mean nothing to them.
IMHO, it would be a weekend workshop, where you build a basic printer kit, then learn how to deal with electronics and software and finally print the first test cubes as minimum goal.
-Olaf
Re: Build your own 3d printer class July 21, 2015 01:07PM |
Re: Build your own 3d printer class July 21, 2015 01:30PM |
A weekend!Quote
Kurzaa
I agree with Olaf, the idea of a weekend workshop sounds a lot better.
Kurzaa
Re: Build your own 3d printer class July 21, 2015 03:04PM |
thetazzbot
It just seems harder to explain how a delta works than a cartesian
thetazzbot
And debugging them can drive a person crazy... or to drink...
Re: Build your own 3d printer class July 24, 2015 12:27AM |
Re: Build your own 3d printer class July 26, 2015 06:46AM |
Re: Build your own 3d printer class July 26, 2015 06:55AM |
Re: Build your own 3d printer class July 26, 2015 02:43PM |
Re: Build your own 3d printer class July 27, 2015 02:54AM |
Re: Build your own 3d printer class July 27, 2015 04:59AM |
o_lampe
Leaving the students alone with the build would require a good build manual. Which isn´t always the case.
o_lampe
And if there is a good manual, what would they need the workshop for?
The reason to spend money for a workshop is to have an expert at hand, who can answer questions, and also to have access to the right tools for the job. ( solder-equipment, multimeter, caliper )
Re: Build your own 3d printer class July 27, 2015 07:16AM |
The goal would be one class, one printer kit, e.g. everyone builds the same printer, to get people up to speed. Also should mention that the intended audience isn't the person who doesn't know a phillips from a straight edge. There is a prerequisite of basic knowledge..
Re: Build your own 3d printer class July 27, 2015 08:07AM |
ntoff
If someone is knowledgeable enough to build an entire printer kit within a day then they certainly don't need your class. Sorry to rain on your crazy parade.
Re: Build your own 3d printer class July 27, 2015 11:48AM |
Re: Build your own 3d printer class July 27, 2015 01:30PM |
Re: Build your own 3d printer class February 29, 2016 03:17PM |
Re: Build your own 3d printer class February 29, 2016 03:19PM |
