Nozzle sealing
Posted by leadinglights
Nozzle sealing
July 23, 2015 07:18AM
What is the best method of sealing a screw on brass nozzle from leaking around the threads?
Further info:- I have previously made the nozzles for my 4 printers as on the section on the left in the drawing below. My next printer will have 5 or more hot ends and quick changing of the whole hot end is no longer a viable option so I have opted to use a more standard threaded nozzle as shown on the right
Thanks for any input,
Mike.
Re: Nozzle sealing
July 23, 2015 07:31AM
I would guess Teflon tape, limited to 250C nozzle temperature. However, I believe that according to your diagram, the joint would be self sealing, as the surfaces would expand with heat to seal the thread. No? Have you tested it yet?
Re: Nozzle sealing
July 23, 2015 08:40AM
To cover a wide range of materials I need a maximum temperature as high as I can get it, or at least 300C which precludes PTFE tape. With the coefficients of expansion of brass at 18ppm and stainless steel at 17.3ppm I don't think that the joint would be reliably self sealing.
Has anybody used a soft metal gasket as marked in red in the drawing below.
The best material for this would be 24kt gold, but I think you can understand my reticence to use that here.smiling smiley
Mike.
Re: Nozzle sealing
July 23, 2015 10:51AM
If you really want to use a ring seal as in your latest diagram, then a simple copper ring would work fine imho. And these are available just about anywhere in standard sizes and very inexpensive too.
However, I still believe that heat expansion of the steel/brass thread joint will probably provide a good enough seal for the relatively viscous molten filament - I mean, we are not talking about a gas tight seal here.
Again, a simple 10 minutes test would demonstrate whether I am right or wrong. drinking smiley
VDX
Re: Nozzle sealing
July 23, 2015 11:16AM
... for UHV sealing we regularly used aluminium rings ... gold rings only for special problems, where the costs were negligible cool smiley
Viktor
Re: Nozzle sealing
July 23, 2015 11:21AM
Thanks Andrew, I didn't know that copper ring seals were available: Can you tell me of any stockists of small ones in small quantities? The reason that I am getting a bit paranoid is that with 5 or more hot ends something like 5 times the opportunity exists for something to leak.
Picture below of one of the hot end assemblies.
Mike
Re: Nozzle sealing
July 23, 2015 11:34AM
Hi VDX, I used to work on a Kratos mass spectrometer which had gold ring seals and was baked out at 350C but at 6 grams per kit were not trivial - especially since somebody would contaminate it at least once a month.
Do you know where I could get aluminium O rings?
Mike
Re: Nozzle sealing
July 23, 2015 01:47PM
I bought 10 small copper sealing rings at a local hardware store here in Barcelona, Spain, a few weeks ago. They had them in various sizes, and unit cost was about $0.20. As Viktor wrote above, failing copper, you could use aluminum rings, I don't think it would make any difference in your particular application and cost should be about the same. However, I would expect aluminum rings to be a little bit harder to find.
VDX
Re: Nozzle sealing
July 23, 2015 01:51PM
... here's a check at ebay Germany - should be the same at your location too:
[www.ebay.de]
Viktor
Re: Nozzle sealing
July 30, 2015 12:30PM
Thanks AndrewBCN and VDX. Unfortunately the size of 'O' rings that I wanted were not available on any web site I could find. 3mm OD, 2mm ID is about half the size of their smallest so I had to make my own. Cut from K&S tubing with a 22mm circular saw blade in a Proxxon micromot mounted in a 10" lathe. Cut to 0.6mm lengths in both copper and aluminium - the copper is annealed to dead soft just before installation. Initial trials show they seal don't leak with 200kPa of air pressure.
Metal 'O' rings compared to a U.K. 5p coin.
Mike
Re: Nozzle sealing
July 30, 2015 12:47PM
Looks good! thumbs up
