Are you going upgrade to Windows 10 July 28, 2015 03:25AM |
Re: Are you going upgrade to Windows 10 July 28, 2015 04:00AM |
Re: Are you going upgrade to Windows 10 July 28, 2015 06:05AM |
Re: Are you going upgrade to Windows 10 July 28, 2015 06:36AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Are you going upgrade to Windows 10 July 28, 2015 10:30AM |
Re: Are you going upgrade to Windows 10 July 28, 2015 12:22PM |
Dust
windows 10 compulsory updates == reboots mid print!
If your fine with that, sure upgrade to windows 10.
(or you can get pro version and disable it)
Re: Are you going upgrade to Windows 10 July 28, 2015 01:12PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 01:25PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 01:49PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 02:06PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 02:34PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 02:42PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 02:57PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 03:21PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 03:34PM |
tadawson
You botched something . . . you can reinstall either without affecting the other. Put Windows on part 1, Linux on 2, swap on 3, and whatever on 4 if you like. If/when Windows toofs, reinstall Win*, but do *NOT* allow it to repartition. Then boot into Linux with your CD and put the Linux bootloader back on, so you have access to both. If your Win* partition is smallish (as mine are), you can take an image backup with dd, and if/when it blows, just write the image back to the Win* partition from Linux, and never have to reinstall from the Win* media at all . . .
- Tim
Re: Are you going upgrade to Windows 10 July 28, 2015 03:55PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 06:05PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 06:49PM |
Dust
@DC42
I've been printing direct from a pc for 5+ years, people who say its bad don't have a clue WTF they are talking about.
Granted its a dedicated pc, running linux, to get over the many issues of other operating systems.
Re: Are you going upgrade to Windows 10 July 28, 2015 09:36PM |
the_digital_dentist
I've hated being forced to use Windows for so long that I never consider getting a newer version an upgrade. I've been looking for a way out of Windows for almost 20 years.
Re: Are you going upgrade to Windows 10 July 28, 2015 10:54PM |
Re: Are you going upgrade to Windows 10 July 28, 2015 11:37PM |
Re: Are you going upgrade to Windows 10 July 29, 2015 12:08AM |
Re: Are you going upgrade to Windows 10 July 29, 2015 12:29AM |
Re: Are you going upgrade to Windows 10 July 29, 2015 04:34AM |
tadawson
I would argue that the computer will be more reliable in avoiding data errors than trying to read an SD card over a very crappy chunk of unshielded ribbon cable.
Re: Are you going upgrade to Windows 10 July 29, 2015 04:55AM |
Re: Are you going upgrade to Windows 10 July 29, 2015 07:59AM |
Re: Are you going upgrade to Windows 10 July 29, 2015 08:25AM |
SQLException
Although I can't contribute much to this thread due to a faulty printer, I had a discussion earlier with someone (I'm pretty sure he knows his shit), he told me he would never print from SD.
Re: Are you going upgrade to Windows 10 July 29, 2015 01:14PM |
dc42
tadawson
Modern electronics boards (Duet, Smoothie and clones) have the SD socket integrated on the board.
I can accept that a semi-dedicated PC used for nothing else while a print is running can be reliable enough and fast enough to feed data to the printer. You would want to disable auto downloading of updates, which by the sound of it may be a problem with Windows 10. But I don't want to dedicate an entire PC to my printer. The PC I use for slicing and designing models is the same one I am using to write this reply.
Re: Are you going upgrade to Windows 10 July 29, 2015 01:23PM |
the_digital_dentist
Forgetting all else in the computer vs SD card debate, how hard is it to pull a USB cable out of a computer? That's how easy it is for your computer driven printer to fail.
Once you have your printer working, and then discover all the ways a print can fail (not sticking to the bed, filament tangling on the spool, etc.) by experiencing a few of them, you begin to think about how to make the process more reliable. You remove as many unknowns as possible and develop techniques for dealing with those that can't be removed completely. Computer failure in any form (hardware or software) can be removed by simply not using a computer. Don't worry, even after you remove the computer, there are still plenty of ways for your prints to fail. You'll be studying and thinking and developing your own set of strategies for preventing them for many months.
There in't much more to say about it other than to have you search these forums for "pronterface", "repetier" and other host software names to see the problems people could avoid by not using a computer.
Re: Are you going upgrade to Windows 10 July 29, 2015 02:11PM |
