Re: A practical 10 Cents Ceramic tube hotend November 07, 2015 08:08PM |
Re: A practical 10 Cents Ceramic tube hotend November 07, 2015 11:30PM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 01:05AM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 03:02AM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 03:44AM |
realthor
I can't just yet wrap my head around an object with a single smooth channel, that has 2 zones, one for melting plastic and the other for heatbreak .
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 04:20AM |
etfrench
realthor
Prometheus hot end
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 04:46AM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 05:21AM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 09:51AM |
MechaBits
I think I'm going to stay with ptfe lined idea for time being,
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 10:19AM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 12:21PM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 02:24PM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 02:29PM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 03:16PM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 04:27PM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 05:14PM |
3DS-QUAD
This is my hotend from a fuse and brass coupling, M6 Brass Coupler
It's not tested, I was expecting a compact extruder without a need for fans or heatsink. it looks like the only way to attach this to the x-axis would be a clamp.
3DS-QUAD
making a mold using fire putty may be possible.
encasing a heating block in ceramic would be nice an all in one, heater / nozzle / thermistor. Individually replaceable.
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 06:46PM |
Re: A practical 10 Cents Ceramic tube hotend November 08, 2015 07:20PM |
cozmicray
The red stuff around heating element in pix
is Silicone rubber
NOT ceramic
cozmicray
? What extruder hotend is Lander using?
cozmicray
aerogel insulator
Re: A practical 10 Cents Ceramic tube hotend November 11, 2015 07:20AM |
Re: A practical 10 Cents Ceramic tube hotend November 11, 2015 07:59AM |
Re: A practical 10 Cents Ceramic tube hotend January 24, 2016 09:01AM |
Re: A practical 10 Cents Ceramic tube hotend February 14, 2019 09:35PM |
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 02:31AM |
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 03:17AM |
townkat
cozmicray
[attachment 65585 Thermal_C.jpg]
Why not a Borosilicate (Pyrex) glass bushing/liner (essentially a tube) for the heat breaks with 4.1mm hole (those where the bowden tube go all the way until it touches the nozzle)?
Borosilicate (Pyrex) glass seems pretty close in thermal conductivity/insulation and should be good in strength/non sticking too.
Maybe not expensive either?
Why no one have done it already ..?
What do you think ?
(Hello everyone btw )
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 04:03AM |
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 12:37PM |
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 01:24PM |
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 02:09PM |
Pippy
The idea is never going to go away, just needs someone with that light bulb moment to find that cheap and simple way of making a ceramic like heat break.
Maybe mold one using high temperature JB weld. The 1300C stuff (https://www.jbweld.com/products/j-b-extremeheat) would withstand any hot end .. this could be done by any non-doubting thomas I'm sure.
Maybe use the cheap ceramic fuse idea, put a 1.75mm drill bit (the smooth part) down the center (and firmly centered), then inject between the drill bit and the inner fuse wall with the above JB weld in order to create the 1.75mm channel you so desire ?
A standard ceramic mains fuse here in the UK is extremely strong, I just removed the two end caps off of a standard 13A one, It's I.D is 3.3mm .. maybe someone with the means could try some 3.3mm filament ? .. or do as above to reduce the inner diameter down to 1.75mm'ish ?
I've not yet used JB weld myself, so don't know what it's surface finish is like, but I soon will.
ps. maybe not JB Weld (it conducts heat I see), but maybe something like thermal insulation washers/collars or such like ..
[en-mx.misumi-ec.com]
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 02:11PM |
Re: A practical 10 Cents Ceramic tube hotend February 15, 2019 04:49PM |
townkat
from the table, if the values are correct, thermal conductivity:
ceramic (Al2O3) -> 39
borosilicate glass -> 1.4
small thermal conductivity is essential in this situation.
that's why i am not too much for ceramics but more for glass.. (even standard glass should be good too) i think..
