A practical 10 Cents Ceramic tube hotend
Posted by beyondwind
Re: A practical 10 Cents Ceramic tube hotend
February 15, 2019 04:59PM
the bushing/liner have the purpose of keeping the heat out (down), there is pla filament inside, stainless tube outside
it always happens to those who switch to all metal (heat break) that they can't print pla anymore as it sticks to the stainless tube because it allow heat too go too high, it is called heat creep
i'll try to draw it with words, if it doesn't work i'll try an actual drawing smiling smiley :
it is like this : filament -> inside an insulator tube (ptfe now, borosilicate/glass on my sugestion) -> inside stainless throat/heat break
the target is to avoid heat to go up on the tube as this cause the heat creep, and insulation is much more preferable than cooling
edit: i am talking about standard configuration with aluminium hot end block at the bottom
Edited 4 time(s). Last edit at 02/15/2019 05:01PM by townkat.
February 15, 2019 05:06PM
So the tube is both the heat break and the medium through which heat is transmitted? The ceramic hot ends I have seen have the heating element wound around the outside of the tube. If your design is like that, I suggest you calculate the minimum thermal conductivity you need in order to avoid excessive temperature drop between the outer wall where the heater is and the inner wall where the filament has to be melted.
Heat creep along the tube to the cold end is mitigated by the heatsink and fan assembly. Not ideal, but it works.
Edited 1 time(s). Last edit at 02/15/2019 05:06PM by dc42.
February 15, 2019 05:39PM
no, not ceramic hot end, a bushing/liner inside stainless threaded tube
i am talking about this smiling smiley
February 15, 2019 05:48PM
OK, I misunderstood.
What do you think would be the advantage of a glass or ceramic heat break, compared to the traditional thin stainless steel one?
February 15, 2019 06:34PM
usually printers come with ptfe lined stainless threaded throat/heat break
ptfe is not very heat resistant, it works but even at usual <250 Celsius it does change it's color and deteriorate over time
there is another all metal throat/heat break, which is identically stainless threaded tube but instead of 4.1mm inside hole it does have a 2mm hole so there is no liner used anymore, which works for higher glass temperature materials, but not for pla
this one also needs to be cooled more intensely, so the distance from heater block to cooler must be lower, this also is inconvenient in other ways too: more stress on heater element, slower heating time etc.. -> insulation is more preferable than cooling.
someone sugested that the shorter the melting zone, the more precise the extrusion/printing too
i am suggesting this as a solution which will work in both cases, high and low temp materials
Edited 6 time(s). Last edit at 02/15/2019 08:36PM by townkat.
open | download - hotend.svg (12.4 KB)
open | download - hotend.png (128.5 KB)
February 15, 2019 06:36PM
With a heat break, there is no need to cool the top part of the assembly as the heat won't creep up the stem, or at least most of the heat shouldn't creep up the stem.
This means no more fans or heat sinking vanes etc above the nozzle and it's heating block. The heat stays concentrated in the bottom aluminium/copper block with the nozzle - where it's needed/wanted.
It also means you need less power to the nozzle heater because it's not being wasted up into the above heat-sinking/fan area. So everything becomes lighter and more efficient at doing what's it meant to do (heat the nozzle).
I've just tested a quick induction heater coil in place of the normal nozzle heater, it was a little tooo efficient though, like whatever was inside the induction coil started glowing red hot within 20 seconds or so .. need to down size the induction coil and use much smaller mosfets winking smiley
February 15, 2019 06:39PM
Pippy
you may start printing with metal soon maybe smiling smiley
February 15, 2019 06:47PM
Very nearly !
I don't know what the material is Weller use for their soldering iron handles, but that would work too.
It's some sort of heat proof molded plasticy stuff (the blue handles) it would seem.
February 17, 2019 06:15AM
How is it(the water cooled version) sealed or held inplace
February 17, 2019 07:26AM
What would work as a thermal insulator which could be polished is cubic zirconia , the stuff for fake diamonds. Unlike diamond it has low thermal conductivity and is used for thermal barrier coatings in jet engines.
Cheapish in small quantities, last lot I saw was ~ USD1 per gm uncut
February 17, 2019 10:42AM
What about Water jet Focus tube for nozzle ? Don't now is this suitable, but I know it is very hard, it has super fine finish and it press fit in water jet head by default (for 4000 bar or more). It is expensive OTOH...
Edit:
Here is the link: [www.waterjet-shop.com]
Edited 1 time(s). Last edit at 02/17/2019 11:10AM by tabana.
February 17, 2019 11:24PM
tabana
Stuff I have seen for this is sapphire and it is ~x10 the thermal conductivity of cubic zirc
~24 W/mK vs 2.2 Note optical axis and dopants can vary these a bit
February 18, 2019 07:32AM
Sapphire (and ruby) are materials for water jet nozzle. I think focus tube is made of tungsten carbide, if it makes any difference.
I made this post just to give you another idea, maybe it's not worth to try it.
February 18, 2019 08:19AM
tabana
Can you explain the advantage of these materials for a heatbreak and how you would make it ?
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
February 18, 2019 08:25AM
tabana
This is about ideas hopefully,normally just lurk here but some current stuff involves conductivity of very hard materials (electrical not thermal).
On the thermal conductivity bit WC itself is 110 W/mK but the binder (cobalt?) in "tungsten carbide" will reduce that
Edited to add
There is plenty of gemstone expertise around not so much with tungsten carbide
Edited 1 time(s). Last edit at 02/18/2019 08:32AM by jcamp.
February 18, 2019 09:12AM
MKSA
[how you would make it ?
One off
Gemstone of ebay or local gemshow (cheaper uncut)
Diamond drill 1.5mm hole
Bolt or soldered rod through hole
Toolpost diamond grinder to desired OD
Lap/polish to desired ID with diamond paste
February 18, 2019 11:47AM
jcamp
MKSA
One off
Fine, DO IT, show the results AND document the advantage compared to a SS or even Ti heatbreak as we keep asking !!!!!
February 19, 2019 03:17AM
No, I cant explain nothing about this. This image just reminded me on focus tube spinning smiley sticking its tongue out
February 19, 2019 05:39AM
tabana
I don't care for "image", I care for REAL WORKING stuff !
Looking at your "image", have you ever made a working heatbreak, hot end ?
Edited 1 time(s). Last edit at 02/19/2019 11:29AM by MKSA.
February 22, 2019 03:36AM
I haven't posted here in years but since I experimented a lot with my own design I will give you my ten cents.
Few years ago I designed a hotend that had a quartz tube surrounded with a ceramic body and a elaborate heater block, the quartz tube was about 27 dollars, the ceramic body was printed by shapeway around 60 dollars and the heater block was machined out of brass and it was around 45 dollars so roughly 132 dollars in reality since I did several iterations it was around 800 dollars that I spend on it.
The good: the quartz tube works like a charm, combined with the ceramic body there is no need for active cooling even when printing ABS the maximum temperature at the top of the hotend never exceeded 50 degrees. In theory you could print at very high temperatures.
The not so good: bulky and delicate, even though ceramic is very strong it could brake if you bump it hard enough and there is no universal mount for it so its design isn't as simple as regular aluminum ones.
The bad: EXPENSIVE, REALLY EXPENSIVE. unless you have a klin and machining tools available it is really hard to get it at reasonable cost, also in today's market when a really good and reliable hotend cost no more than 20 dollars and most of the people prints with PLA there is no place for this kind of hotends.
So once it broke because of my stupidity I put it to rest and went back to cheap and simple Chinese hotends.
