Hi Guys,
I have build a Wolfstrap and now I want to print something, but I have a problem now.
I'm using ReplicatorG 18 with the newest firmware. My electronic is the one from Techzone.
If I start the print job, the extruder is warming up and extrude a little bit of abs.
But when the print job starts, the Motor LED light up for a few milliseconds and turn of again and the heater LED also turn of after about a second.
The printer is moving but the extruder does nothing. The temerature reading is still working but the Temp goes slowly down.
I tested different firmware but even the same happens. If I test the extruder with the Control panel, sometime it happens the same problem, then I have to resend the PWM or the Target Temp again to get it working for a while.
I hope someone can help me.
Thanks
Constantine
Edit:
At the moment the extruder board hang up, Replicatorg print this two lines:
"Packet response code: Unknown code"
"Packet payload: empty"
Maybe that help to solve my problem.
Edited 2 time(s). Last edit at 08/08/2010 12:49PM by Constantine.
