Using a Printrbot board
August 08, 2015 01:39PM
Just finished building a printer of my own design. Nothing unique.
The X-Y plane is fixed and Z is up and down. Height is gained by lowing the platform.
I am using a Printrbot Rev D board and every time I start a print the platform goes up about 5mm.
I would like the first movement to be down 5mm.
Using Repetier Host and Slicr and have added G28 to start code.
Do not know G code but have tried to change Z movement in the code to negative with no luck.
Any ideas?
Re: Using a Printrbot board
August 08, 2015 08:12PM
in configuration.h file change
#define INVERT_Z_DIR true / false
then reload firmware
or
change stepper wires
invert plug or swap wires to pins 1 and 2
