pla vs as problem
August 09, 2015 03:47PM
decided to try pla again today but a weird thing is i printed the same object abs and pla the pla is the purple in pic whys it prints lines apart where as abs was all together
abs was 237
pla 200 all other settings same
Re: pla vs as problem
August 09, 2015 05:15PM
Maybe your bed warps at print temperature. Did you try rezeroing?
August 09, 2015 06:21PM
Possible that you are under extruding with the PLA? What slicer are you using? There could be some settings that are different between ABS and PLA if you use different profiles.
August 09, 2015 06:50PM
i did think the pla was extruding slower was using cura and sd card
will try with slicer on pla see what happens
August 11, 2015 05:17PM
right tryed abs again but same
put new e3d v6 nozzle and heat block on too
all extrudes fine when i go on lcd and prepae extruder all comes out ok
but when i click a print off lcd it takes ages for it even to start brim which is set to 6 rounds i n slicer and when the print itself starts from centre the layers are all messy not alighned and together
the bed and z axis have been checked numerous times and leveled
what do i change to set if under or over extruding
getting to end of my teather
August 11, 2015 05:32PM
Sounds like your LCD is picking up some interference or possibly the cable is to long introducing data errors, just a thought.
August 11, 2015 06:29PM
yes will try computer next as reset configs diferent temps u blocked etc
August 12, 2015 03:07PM
finally a little success swapped to usb and cura had to print a t 230 for pla to come through better but not perfect
but better than sd print
anywat tryed pronterface as what used before cura and lcd just could not get to extrude or print
so thought would give repetier a try as could not work when first had
had to print a small object after i had reet some settings and so far still printing looking good
thanks for suggesting to go back to usb sounds like the lcd playing up
can i save config files of settings from repetier will post pic tommorow
August 13, 2015 11:02AM
why does the 45 layer go funny when the rest ok
