ReplicatorG 0018 Compatible with Mendle 5D? August 07, 2010 02:53PM |
[!-- RepRap Mendel --] [machine] [name]Mendel[/name] [geometry type="cartesian"] [!-- different pulleys on X and Y axii --] [axis id="x" length="200" maxfeedrate="3000"/] [axis id="y" length="200" maxfeedrate="3000"/] [axis id="z" length="140" maxfeedrate="90"/] [/geometry] [tools] [tool name="Wade's Geared Extruder" type="extruder" material="PLA" motor="true" motor_steps="200" floodcoolant="false" mistcoolant="false" fan="false" valve="false" collet="false" heater="true"/] [/tools] [clamps][/clamps] [driver name="sanguino3g"] [portname]/dev/ttyUSB0[/portname] [rate]19200[/rate] [parity]N[/parity] [databits]8[/databits] [stopbits]1[/stopbits] [debuglevel]0[/debuglevel] [/driver] [warmup] [/warmup] [cooldown] [/cooldown] [/machine](Forum software doesn't seem to like "<" and ">". Changed to "[" and "]".)
[13:47:40] Loading driver: replicatorg.drivers.NullDriver [13:48:36] Loading machine: Mendel [13:48:36] Loading simulator. [13:48:36] Loading driver: replicatorg.drivers.gen3.Sanguino3GDriver [13:48:40] Read timed out. [13:48:40] Read timed out; giving up on query. [13:48:47] Read timed out. [13:48:47] Read timed out; giving up on query. [13:48:47] No connection; trying to pulse RTS to reset device. [13:48:54] Read timed out. [13:48:54] Read timed out; giving up on query. [13:48:54] Unable to connect to firmware.
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 07, 2010 03:50PM |
Admin Registered: 17 years ago Posts: 7,879 |
I can't get the version of skeinforge that it comes with to use E codes.
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 07, 2010 04:08PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 08, 2010 08:23AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 09, 2010 02:17PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 10, 2010 04:59AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 18, 2010 06:04AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 18, 2010 06:15AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 18, 2010 07:12AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 18, 2010 11:09AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 20, 2010 03:21AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 26, 2010 02:03PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 26, 2010 04:49PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 26, 2010 05:11PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 26, 2010 09:01PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? January 03, 2011 02:56PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? January 03, 2011 03:13PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? January 04, 2011 01:38AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? January 08, 2011 01:40AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? January 08, 2011 01:54AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? January 08, 2011 05:26PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? May 18, 2011 12:50AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? May 18, 2011 09:44PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? May 19, 2011 12:07PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? May 19, 2011 12:25PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? May 20, 2011 06:18AM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 01, 2011 12:27PM |
Re: ReplicatorG 0018 Compatible with Mendle 5D? August 01, 2011 02:33PM |
