Pop! Goes the Power Supply August 15, 2015 01:32PM |
) so I disconnect it from my printer, and crack it open.|
Re: Pop! Goes the Power Supply August 15, 2015 02:01PM |
Re: Pop! Goes the Power Supply August 15, 2015 08:57PM |
Re: Pop! Goes the Power Supply August 15, 2015 09:00PM |
tmorris9
What caused it is either A: you caused a short circuit during your wore management (wire pinched or bare section contact) or B: it was just your power supply failure time <---- Less likely.
So you need to find the problem with the wiring and fix it before you hook up another supply. I would match the output of the original supply at minimum. So if it was a 30A then buy another 30A.
Re: Pop! Goes the Power Supply August 16, 2015 06:16AM |
Re: Pop! Goes the Power Supply August 16, 2015 11:22AM |
AndrewBCN
All your questions about power supplies are answered in (surprise, surprise...) the wiki.
Choosing a Power Supply for your RepRap
Re: Pop! Goes the Power Supply August 16, 2015 12:49PM |
Re: Pop! Goes the Power Supply August 16, 2015 12:54PM |
dc42
Your main choices are the following:
1. Cheap ATX PSUs. The 12V regulation is typically poor and the PSU may be unreliable. Not recommended.
2. Cheap LED/CCTV power supplies. This is probably what you had. They are entirely adequate when they work, but may be prone to infant mortality. I use them in both my printers. I haven't had one fail yet, but I have heard of this type of PSU failing (like yours). I have also heard of them surviving output short circuits without damage. An advantage over ATX PSUs is that you can generally turn the output voltage up a little, which may be useful if your heated bed struggles to reach the required temperature. They generally have exposed terminals, so you need to print a cover to go over them for safety. At least some brands use leaded solder and so are not RoHS-compliant.
3. Expensive branded ATX PSUs. These generally have decent regulation on the 12V rail, but need a minimum load on at least the 5V rail to work reliably. If you get a "modular" one then you are spared a mess of unused cables. I used a Corsair CX-430M for a while and found it satisfactory.
4. Expensive LED/CCTV etc. PSUs such as you can get from Meanwell, RS Components and other component distributors. Hopefully more reliable than the cheap LED/CCTV supplies, but might be made in the same Chinese factories for all we know. I have no experience of them.
Re: Pop! Goes the Power Supply August 16, 2015 01:21PM |
Re: Pop! Goes the Power Supply August 16, 2015 01:23PM |
madmike8
I use a USFF Dell 220W 18A DA-2 Power Brick. I used it because it was free to me. So far, so good on my Funbot with 4 steppers, SmartLCD, MK3 Aluminum Heatbed, and 40W hotend. I've only been running it a couple months, so I can't tell you it will last long term. But it's worth a shot if you can get it free.
Dell USFF DA-2 Mod Link
Re: Pop! Goes the Power Supply August 16, 2015 01:33PM |
MegaRocketPenguin
Thanks for the info, will keep it in mind when I go on a trek for a power supply. Any thoughts on laptop charger/power supplies and the Dell mini power supplies? (Might be able to get my hands on one of those for free...)
