Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? April 20, 2016 10:50AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? April 20, 2016 11:34AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? April 20, 2016 12:21PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 28, 2016 08:43AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 28, 2016 02:31PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 28, 2016 03:52PM |
bigfilsing
these kind of sensors are used all day every day in industrial applications. So what are you posting in your thread ???
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? October 29, 2016 12:13AM |
dc42
bigfilsing
Yes, but only to detect that a object is near - not where triggering at a precise distance from a target is required.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? January 08, 2017 07:55AM |
JBFUK
My LJC18A3-H-Z/BX has started to let me down. First of all I've been finding the results inconsistent. If I go to one part of the bed, home Z then manually move the probe down until my nozzle is 0.1mm above the glass I get a different result to that on another part of the bed - sometimes as much as 0.3-0.4mm which makes it hard to find a decent z-offset and leads to failed prints due to the first layer not going down properly.
Also had a couple of instances in the past week where the sensor fails to detect the bed, luckily I was watching and killed the power. I found it started working again after squeezing the probe shaft with some pliers.
I don't know whether it's just my sensor playing up or whether capacitive sensors are inherently unreliable/inconsistent. Don't know whether I should order a new sensor or look at other options like a servo/switch based probe.
Anyone else had similar problems?
(EDIT)
Have ordered a replacement capacitive sensor for now and have ordered one of these as a longer term solution although it may take a few weeks to arrive from Oz (http://aus3d.com.au/electrical/endstops/ir-z-probe). I think ultimately this will be a more reliable solution and should hopefully allow me to switch out build plates without having to adjust the z-offset.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 10:28AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 11:13AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 11:23AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 11:55AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 12:02PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 12:07PM |
heatvent
UPDATE: I tried wiring the sensor directly to 12V with the signal pin disconnected to see if I get better range on the sensor. While the LED light does seem brighter when triggered, I still need to literally touch the sensor head in order to get it to trigger. Any idea if I have a bad sensor and/or if there is a sensitivity adjustment?
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 12:16PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 01:21PM |
heatvent
Thanks for the reply. FYI no dim light for me it's just off and on when triggered. Can you give me an idea how the sensitivity adjustment screw works. I turned it about 11 times and it doesn't seem to stop anywhere and also doesn't seem to affect the sensitivity. There are no indicators on the top to show how this should work. For example turning right is more sensitive or less sensitive… Not sure. Any advice would be appreciated.
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? February 04, 2017 07:49PM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? March 07, 2017 03:29AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? March 07, 2017 05:31AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? March 08, 2017 04:06AM |
VJain
Hey everyone,
I am looking forward to install a NPN NO capacitive sensor to autolevel a delta.
But I need help regarding the bed surface. It doesn't sense a transparent glass but it does sense a mirror glass from a fair distance. The sensitivity is 10 mm.
Will it sense a transparent glass plate that has been painted black on one side ?
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? March 08, 2017 05:27AM |
dc42
VJain
Hey everyone,
Capacitive sensors are the least good option. See [www.youtube.com].
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? March 08, 2017 09:10AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? March 23, 2017 10:47AM |
Re: Best Capacitive Proximity Sensor for Glass Sheet on PCB Heater? March 23, 2017 11:15PM |
