Part prints taller than the stl settings August 21, 2015 07:35AM |
Re: Part prints taller than the stl settings August 21, 2015 12:40PM |
Re: Part prints taller than the stl settings August 25, 2015 12:46AM |
Re: Part prints taller than the stl settings August 25, 2015 10:42AM |
Re: Part prints taller than the stl settings August 27, 2015 06:14PM |
Re: Part prints taller than the stl settings August 27, 2015 06:30PM |
elwood127
Hey DC, I'm having a heck of a time trying to find out how to change my Z Steps. Where will I find my gcode file and what text editor should I use to view it? Prusa I3 w/ Later Melzi board, Repetier and Slic3r. Thanks.
Re: Part prints taller than the stl settings August 28, 2015 07:58PM |
elwood127
It will not highlight in the menu so I can't click it. Any idea why this is. Thanks.
Re: Part prints taller than the stl settings August 28, 2015 10:08PM |
Re: Part prints taller than the stl settings August 29, 2015 04:58AM |
elwood127
Ok 3Dkarma and gmh39, no M commands have any effect. I can see the command in the log but nothing appears accept for 3 second temp checks.
elwood127
Also, where do I enable EEPROM in Repetier?
elwood127
I've been through every file folder regarding Repetier and there is no Configuration.h file or anything regarding settings either in EEPROM or firmware.
elwood127
No offence but I have gotten both of your replies 20 times but no one has the actual answer to where to find the files to look at in wordpad or why entering mcode into Repetier's gcode editor has no effect.
elwood127
Is anyone actually using Repetier and a Melzi controller?
