Stainless Steel Rod Sculpture
August 23, 2015 04:38AM
HELP PLEASE.
Hi all. New to site trying to find answers on what guage of stailess to use for a wind sculpture for outdoors.
We are wamting to use stainless rod between 4 and 8 mm Im thinking in lengths up to 4- 5 mtrs high.
What would be the ideal size does anyone know that will not bend over totally under its own weight? We want it to flex and sway without failing. It will be fixed to the ground vertically in numbers to flow and move with breeze. It needs to be able to withstand quite high winds at times. Imagine grasses in a breeze. Flexing and flowing.
Any comments and advise welcome please.
Regards
Mark
Edited 2 time(s). Last edit at 08/23/2015 04:41AM by Waterfront.
Re: Stainless Steel Rod Sculpture
August 23, 2015 10:11AM
If you can“t figure it out yourself, do you believe someone else would take the responsibility to give advice? ( I know, we have skilled people here )
Imagine, the project fails and people get hurt....
-Olaf
August 23, 2015 10:28AM
I suggest you invest in a single rod and see how it behaves. A single SS rod won't cost much and will answer all your questions and more.
August 23, 2015 11:35AM
It is totally depending on the geometry of whatever you are intending to do. Without a full drawing or model no one can give a meaningful answer.
August 23, 2015 01:04PM
Offhand, I'd say 4mm dia rod, 5m long would fail. 8mm might be OK but it would sway a lot. 10mm or larger might be a better choice. Whether it fails or not would depend a lot on what alloy and temper you pick. Yield strength of different stainless alloys can vary from ~30,000 PSI to 300,000 PSI. I'd try prototyping with re-bar which is cheap and available. The stiffness of plain steel re-bar is about the same as stainless so the swaying properties will be about the same. However, re-bar won't be as strong, so in high winds, it will fail more easily.
August 23, 2015 02:41PM
Hi All,
Thanks for the comments and thoughts.
I was not trying to put anyone on the spot or hold in any way responsible I was just hoping to get some ideas which I have now gained.
The idea that I sample a few sizes is good which I will try as I really had no idea how it might react. Clearly too small wont work. As will too big not work obviously.
Thanks to all for your thoughts.
Regards
Mark
