need help troubleshooting an error!
Posted by ilaz
August 24, 2015 06:36PM
Error:0
: Extruder switched off. MAXTEMP triggered !
This is the error I get when connecting my printer to pronterface, and it turns off everything. How can I fix this? I am not even using a hotend, is there a way to change the firmware to remove this issue?
Thanks.
Re: need help troubleshooting an error!
August 24, 2015 07:37PM
Do you have your thermistor set correctly?
August 24, 2015 08:35PM
I'd guess it's *because* you don't have a hotend. The thermistor input is open-circuit, and is interpreted as some very high temperature.
Try putting a resistor (say 100K) across the thermistor inputs.
