Cartesian Platform Built From Old Flat-Bed Scanners?
Posted by Anonymous User
Anonymous User
October 06, 2007 01:31AM
Obsolete flat-bed scanners seem to be commonly available in local thrift shops for a few bucks. Has anyone attempted to reuse the interior mechanisms to build a cartesian table? Seems like a natural if it can withstand the stresses.
VDX
Re: Cartesian Platform Built From Old Flat-Bed Scanners?
October 06, 2007 03:45AM
Hi drvanthorp,
... most cartesian plotters have rails, which are fixed only on one side, the other runs free on a roll, so the rail isn't stable enough to move the extruder without deformation ...
I found on both sides feeded rails (wire-moving) in old XY-writers and used this principle on a laserplotter-design, what worked very well - if you want a sketch, i can draw it ...
For a lightweight-toolhead, as a laserdiode or so, it would go anyway.
If you want to reuse the mechanics - the X-motor (for the rail) is mostly good enough, the Y-motor (pen) is in general to weak ...
Viktor
October 19, 2007 05:30PM
How about moving the object around instead? Most parts are quite small and lightweight.
VDX
October 20, 2007 02:08AM
Hi mimarob,
... you must have a plain and stiff table under your object, so the most weigt is in the surrounding hardware, not the objects himself ...
I'm on prototyping different approaches with a diode-laser-fiber in the head, here the moving mass is so small, that a normal plotter wouldn't sense the difference to a pen ...
Viktor
