Water-bath printing
Posted by jbayless
Water-bath printing
August 12, 2010 01:59AM
Hello,
Last night in the shower I had an idea. What if, instead of heated beds and build chambers, the answer is just the opposite - flash cooling of the printed filament?
So here's my proposal: A Darwin-style axes arrangement, with an X and Y gantry above and a Z bed below. The Z bed is put just above a bath of water (the height of which is under closed-loop control via a pump and drain), so that as it lowers down it can submerge into the water.
As each layer is printed, it undergoes rapid cooling via the bathwater. My intention is to resolve three problems:
1. Maximum print speed. Some users have posted about how tall narrow parts require cooling between layers to prevent the prints from getting messed up, because the next layer begins before the previous one has had time to cool off. I believe this setup will eliminate print speed limitations, from a thermal point of view. Which is good because I see print speeds increasing signficantly in the future as software improves, as bowden-cable extruders take root, and as multiple-print-head systems start to allow for rapid infill with an infill nozzle.
2. Part warp. By cooling the filament as soon as it's laid down, I hope to reduce the build-up of thermal stresses leading to parts warping. This is somewhat counter-intuitive, and I'm not sure it will work.
3. Support material. Raising the water level just below the print level, that is to say the height of a support layer, might allow printing arbitrary overhangs. The hot plastic will hit the water and should instantly harden.
To avoid creating waves in the water bath, the print bed might need to be somewhat porous. It might also be beneficial to increase the viscosity of the water (such as by adding a starchy thickener) or reducing the surface tension (by adding a detergent).
Re: Water-bath printing
August 12, 2010 02:51AM
And if you print with 30% infill, your Objekt is 100% infill with Water winking smiley grinning smiley
Mfg
Wolfgang
August 12, 2010 10:38AM
I have wondered about the same thing, too. I believe that ABS is slightly denser than water, but it is close enough to act as support material. Instant cooling may decrease the bonding between layers, but make overhangs much stronger.
The very narrow tip of may latest glass nozzles has made me think about what new techniques they can open up. I was thinking about Z axis extrusion. Move the Z axis upward, slowly, along with X and y if a tilted strand is wanted, and extrude VERY slowly, so that it has a chance to harden and support the next little bit. Buttresses and internal supports can be made this way. And maybe even flat, horizontal spans. Can't wait to get a machine working to try it. I want to be the first to make a single strand ARCH!
Mike
August 12, 2010 11:27AM
jbayless - Would be great fun to experiment with. You could also try a cool air jet blowing across/ inside the part as it printed. (Attach it to the print head).
Just don't get the hot bit wet !
August 12, 2010 01:50PM
Greetings all,
Most of the "engineering plastics" I've worked with have densities around 1.4 g/mL. Most plastics will sink in water, unless they are foamed.
A possible problem with such rapid cooling is that it may prevent subsequent layers from sticking to the already-printed ones. (I think that good layer-layer bonding results from the new layer just barely melting a very thin region of the one it's being laid down on. If that layer is too cold, the bond may be weak.
Of course, one could use a bath of some other liquid. The Bismuth/fuse alloy metals come to mind. And I've also wondered about deep eutectic solvents, but those are still quite pricey. (There is one whose ingredients are inexpensive -- Urea and Choline Chloride, but the combo is still not readily available.) I wish I had a fume hood....
August 12, 2010 02:20PM
My intention wasn't to float the plastics on water or to take advantage of buoyancy in any way, just to make use of the rapid cooling to avoid the need for support.
If weak inter-layer bonding turns out to be an issue, then the water level might need to be lowered during some print operations to reduce cooling, and raised at other times (such as when support is needed or faster cooling is beneficial).
But I wonder if there might be a better solution to improve inter-layer bonding as well. Since heat can be rapidly removed from the printed object by the water bath, it might be feasible to use intense local heating directly where the filament is applied to bond it strongly to the layer below, followed by the subsequent rapid cooling. Just a thought...
August 12, 2010 03:22PM
I put a lot of effort into keeping the object warm to reduce warping, so I would guess that cooling it quickly will maximise warping unless you heat the water to just below Tg. The problem then would be water vapour as water at 70-80C is going to evaporate pretty fast.
August 13, 2010 10:15PM
I think you need to watch a bunch of plastics too as they are hygroscopic (absorb water) to some degree or other. How much water the plastic has taken up can affect it's melt/remelt and fusing characterisitcs.
On stickyness the technique we are using is FDM (Fused Deposition) if too cold it dont fuse.
There is however perhaps a case for a hot water bath to reduce warping and as a support medium. Maybe by flooding the chamber to the layer below the one you are curently printing on. But need to watch out for the hygroscopic and fusing thing.
A dimesnion machine I used once seemed to maintin the build chamber at 80 Degrees C. It printed ABS and used another ABS like material (but coloured grey) as snap away support.
It would be fun to try but personaly I can't see enought gain in it to spend the time.
On other uses for glass nozzles, what about paste/fluid dispensing and or a home made inkjet head...........
Necessity hopefully becomes the absentee parent of successfully invented children.
August 14, 2010 04:16AM
Just a thought. What about two nozzles near the printhead? One blows heated air and the other cooled air, both under software control.
August 14, 2010 08:44AM
on printing in exotic environents.
there is perhaps some mileage in printing in a tank or chambger filled with a gas other than air.
It is common in scuba diving and when making double glazing to fill insulating gas spaces with argon as it is a very poor conductor of heat.
water conducts heat a bunch more than air. but argon conducts it less still.
keeping the build temps from droping too quickly may help fusing and reduce warping.
it does push the costs and fuss factor up a lot though.
August 14, 2010 04:28PM
Yes... Yes!! I think this idea has a huge amount of merit. The cold air nozzle could be an upturned compressed air canister; those emit a very cold blast. And a heated air jet is easy enough to create.
Warping... let's think about it . As I see it, the problem of warping stems from thermal contraction after the filament is laid down, which applies stress to the layer below (which, if cool, has already contracted). For a given filament, the rate at which it cools does not affect the stress from contraction after it's cooled. The problem is the difference in the filament length before and after it cools, compared with the cooled substrate length.
This image shows the cause of warping. The hot freshly printed layer contracts when it cools, shortening its length. The cold layer below has already experienced contraction. When the top layer cools, it stresses the layer below. In this image I've assumed a hypothetical case where there is no thermal conduction between layers; this is a worst-case scenario. In reality, a lot of the heat from the top layer would conduct to layers below.
That heat would cause the layer nearest to the top to re-expand slightly, which reduces the warping force when they both contract again afterward. But even with thermal conduction, the second layer from the top will not be as hot as the uppermost layer.
Now, having a heated build chamber is one solution to this problem. It makes the ΔT between the fresh, hot layer and the substrate layer as small as possible, which minimizes the warping force. But it actually shouldn't be necessary to heat the whole object; just the immediate location around the print head.
If you take any section of an un-warped object, and heat it then and cool it, the end result should be the same as what you started with. The part that you heated up will expand, and then when it cools it will return to its original length (provided that the heating was not so large as to cause it to melt, which would make the internal structure shift around to something new).
Having a jet of hot air, or even a hot needle, locally heating up the point of the plastic exactly where the new filament is laid down, followed by a rapid cooling of both, would probably eliminate warping. If the top area is heated to about the same temperature as the fresh filament, then the two cooled together, will result in no thermal stresses because their nominal lengths will be the same.
Here the area just in front of the print head is flash-heated, while the area just behind is flash-cooled. This results in a temporary thermal expansion in the material just below the print head, which gives that material the same nominal length as the printed filament. When the two are cooled together, there are no thermal stresses left anywhere inside the structure, and zero warping occurs. As an added benefit, the layer-to-layer bond might be even stronger than in a standard print.
An upturned air canister would likely be quite effective as a flash-cooling method, but require frequent replacement -- this would probably contribute a lot to the cost of each print. A water bath could probably serve a similar role. However, as pointed out earlier, it might be necessary to consider the problem of hygroscopy, which I hadn't thought of when I first imagined this method.
August 14, 2010 05:46PM
I don't think the cooling has to be so fast. It only has to be fast enough that when you start the next layer, the previous layers are mostly solid. A fan working as a global cooler might be enough.
I believe developing a local heater will also be useful if you want to extruder threads smaller than 0.2 mm. The problem with thin threads is they don't carry much heat to melt the previous layer and bond to them. Having hot airflow would help a lot.
If their is a way to divert the airflow around the heater, the local heater could be changed into a local cooler to help print overhangs by freezing the plastic as it comes out.
Darwin clone, Gen 2 electronics, Arduino Duemilanove w/ AtMega328, 5D Firmware, Pinchwheel extruder
[www.codeerrors.com]
VDX
August 14, 2010 05:59PM
... i was thinking ataching some of my 5Watt-diodelaser-fibers around the printhead - first for heat-curing when printing with paste, second for heating/fusing the tray to the base when printing with a plastic extruder.
For the diode-lasers the material has to be dark for better absorbing the energy, but if you use an heating halogen-bulb or some orange glowing nicro-wire-windings near the surface, you can go away with white or transparent plastics too ...
Viktor
August 14, 2010 06:01PM
Yes, I think you're right... maybe the cooling isn't even necessary. But it would help with overhangs. =)
August 14, 2010 06:18PM
What if the infill was done with a zigzag where the spacing of the zigzag was the same as the spacing of the infill of the layer below. Would the warping stress then straighten the zigzag rather than warping the part? It seems to me that straight lines for infill would be worst case for warping.
August 14, 2010 06:35PM
Forgetting the overhang for the moment, probably the heating may do the job. Now the hot air is going to need to be fed around the extruder nozzle because you do not know which direction the head is moving relative to the table.
So this means the nozzle is going to require another barrel around it. This may not be as difficult as it sounds - just some more nichrome? wire wound around yet another larger brass tube and air forced down the inside of it, with the extruder nozzle in the centre of this. For the air flow, a small model turbo fan and esc from hobbyking would work quite simply I think.
VDX
August 14, 2010 06:47PM
... hot air is ways to 'diffuse', you'll heat a big areal around the printhead position and every convection or sidestream will change the melting area undefined eye rolling smiley
Better use some directed heat - small halogen lamps directed on the point under the nozzle or a glowing nicro-wire ring around the nozzle ... but with some insulator (maybe a reflecting tube round the nozzle), so the extruder isn't heated from the tip too ...
Viktor
August 15, 2010 05:33AM
hmmmm i like the idea of using halogen heating.
a couple of low voltage halogen bulbs with metal reflectors would be good.
the dichroic reflectors for halogen downlighters let a bunch of the heat out of the back.
August 15, 2010 08:25AM
I've use aluminum tape [www.mcmaster.com] on my hot end. It might make an easy to apply reflector, though it is a bit expensive if you are only using it once.
August 16, 2010 08:28PM
I may be able to do a double glass nozzle design, too, to all piping in hot or cold air as needed right around the filament just as it comes out. I like the idea of flash cooling to make vertical bridges. I was also thinking that slowing the extrusion and X-Y motion way down to allow it to cool normally might have the same effect.
Sorry JB, we seem to have hijacked your thread and diversified into many other thoughts on improving bridging over open spaces.
August 16, 2010 09:01PM
That's ok. I like to think that I'm somehow partly responsible for all the good ideas being generated, even if they are off-topic. ;-)
Slowing the extrusion with no active cooling might have a similar effect, although there's probably only so much that a filament can cool when the hot extruder is sitting right on top of it. And it would certainly increase the printing time of an object.
For flash cooling, if a pressurized air canister is too expensive and a fan doesn't provide a cool enough airflow, it might be fun to try to print one of these:
[en.wikipedia.org]
Edited 1 time(s). Last edit at 08/16/2010 09:07PM by jbayless.
VDX
August 17, 2010 04:10AM
... i think, printed vortex-tubes won't work with enough efficiency - we had a vortex-cooler-head atached to a millhead which emitted cold air with nearly -20 centigrades at 6bar@200lph flow eye popping smiley
I don't think you can achieve this with the needed stability and accuracy ... inner surfaces have to be really even and smooth ...
Viktor
August 17, 2010 11:34AM
I think nophead is on the right track - use the bath as a heated chamber rather than for flash cooling. Instead of a water bath, I'm sure another fluid may be workable - perhaps propylene glycol?
[haveblue.org]
August 21, 2010 11:29PM
I've been pushing this idea arround for a while - Using a heated oil bath - To reduce warping and as a support medium. I was planning on oikl because it is more consistent under temperature variations - so I can keep it heated without distorting it's properties too much (Whereas water will evaporate quickly when kept at 60 degrees).
The oil was intended to allow much more extreme overhangs than current - There will still be limits (unless I can find a print material that is more boyant than the support liquid) however reducing that constraint would be nice.
It does raise the issue of "tall" lines not cooling enough.
Various Glycols are much denser than the oils I was intending however I am approaching this from a handyman perspective rather than a scientific one (I like 3D printing for what I can make rather than the "coolness" of the technology itself)
I don;t see myself being ready to start experimenting with the "print bath" until at least late September (Due to all the other things on my list to do)
Anyone already tried this?
August 23, 2010 02:19PM
I don't think buoyancy is a critical factor for support material. Gravity is not a strong force when dealing with these thin filaments; adhesion is the primary concern. Experiments have shown that Mendel can print upside-down, for example.
A hot oil bath is unlikely to work as an effective support material, even if the oil is very dense, because the plastic won't adhere to it.
My original recommendation of cold water was based on the fact that the water will flash-cool the filament, causing it to harden in place. Not based on buoyancy from the water.
