Stepper motor turning in both directions?
September 02, 2015 09:33PM
I had to rewire some of the electronics on my printer recently. Instead of moving, one of the stepper motors would vibrate. With a closer inspection, I realized the motor was trying to spin in both directions, which created the vibration. I believe there's an error with the wiring of the electronics, but even after several rearrangements of the wires on the motor, it would do the same thing when a signal is sent. I checked my wiring multiple times to make sure it was the same as before with the correct current, but the problem still occurs. All the other motors are working fine, what should I check for now?
Re: Stepper motor turning in both directions?
September 02, 2015 09:49PM
Have you tried the motor with another driver, and vice versa?
September 02, 2015 10:55PM
Thanks, I've fixed it! there was a loose connector and it just required some soldering smiling smiley
Edited 1 time(s). Last edit at 09/02/2015 10:56PM by 4Lyfe.
September 03, 2015 03:47AM
Good to know, you found the cause.
For future readers with the same problem:
Try to switch the outer two wires of the 4-pin connector.
-Olaf
