I don't like uploading solids files because all these file formats seem to be loaded with Metadata.(if I use mastercam to make G-code from an .stl it has the original solidworks file import data listed in the code as a comment.)
Does anyone know of a way to purging metadata from solids files? An application that works with a number of formats and lets you edit this type of thing for instance?
Alternatively: an application that can read .sldprt or .stl files which will overwrite this metadata in the process of saving them from that program?
Edited 1 time(s). Last edit at 08/15/2010 08:09PM by JohnnyCooper.
