what is the trend in build platforms solutions atm? September 17, 2015 05:44PM |
Re: what is the trend in build platforms solutions atm? September 17, 2015 08:14PM |
Re: what is the trend in build platforms solutions atm? September 17, 2015 10:47PM |
Re: what is the trend in build platforms solutions atm? September 17, 2015 11:30PM |
Re: what is the trend in build platforms solutions atm? September 18, 2015 05:44AM |
Re: what is the trend in build platforms solutions atm? September 18, 2015 08:48AM |
Re: what is the trend in build platforms solutions atm? September 18, 2015 11:00AM |
Re: what is the trend in build platforms solutions atm? September 18, 2015 05:51PM |
Re: what is the trend in build platforms solutions atm? September 19, 2015 02:48AM |
Re: what is the trend in build platforms solutions atm? September 19, 2015 09:23AM |
Re: what is the trend in build platforms solutions atm? September 19, 2015 09:27AM |
realthor
I see that MIc-6 is an Alcoa-patented product and i don't know about the availability of this in different parts of the world. I am based in Europe and so far am not aware where can I order such a plate around here. Is there any good alternative to this?
Cast Aluminum Tooling Plate or Jig Plate
Is known by various trade names:
Mic 6® (a registered trademark of Aloca Inc)
Alpase K100-S® (a registered trademark of TST, Inc)
Alca 5™ (a trademark of Aluminum Company of America)
Vista Metals ATP 5™ (a trademark of Vista Metals Corp.)
Alimex 5083
Re: what is the trend in build platforms solutions atm? September 19, 2015 10:27AM |
Re: what is the trend in build platforms solutions atm? September 19, 2015 11:13AM |
realthor
I've read that PEI is a good option used by some printers. How do you stick PEI to the aluminum? And as far as I know PEI can be used to max 217deg or so. What about printing higher temp plastics? Can one print straight on the aluminum?
Re: what is the trend in build platforms solutions atm? September 19, 2015 12:21PM |
Re: what is the trend in build platforms solutions atm? September 19, 2015 12:47PM |
Re: what is the trend in build platforms solutions atm? September 19, 2015 03:28PM |
Re: what is the trend in build platforms solutions atm? September 19, 2015 03:54PM |
Re: what is the trend in build platforms solutions atm? September 20, 2015 02:03AM |
Re: what is the trend in build platforms solutions atm? September 20, 2015 02:56AM |
You will have to use the right grease, there are a few to chose fromQuote
realthor
Question: if a heated bed is involved and an enclosed chamber is built around it to have 40-50deg inside for printing with plastics that require this, isn't any kind of bearing grease going to melt? As far as I know, all bearings have to have some kind of grease to properly function.
Re: what is the trend in build platforms solutions atm? September 20, 2015 05:12AM |
Re: what is the trend in build platforms solutions atm? September 20, 2015 08:37AM |
Re: what is the trend in build platforms solutions atm? September 20, 2015 11:48AM |
realthor
So if i use the right type of grease in the radial bearing with a proper seal then the grease will not melt and the soot/whatever debris will not go inside the bearing even if i choose to roll the bearings straight on the tooling plate's edges right?
wetsparks
Whats the best/preferd method of heating the tooling plate?
Re: what is the trend in build platforms solutions atm? September 20, 2015 01:00PM |
Re: what is the trend in build platforms solutions atm? September 20, 2015 05:24PM |
Re: what is the trend in build platforms solutions atm? September 23, 2015 11:57AM |
info.craftechind.com
Plastic bearings do not transfer heat to other areas of the mechanical assembly.[...]
Nylon is quiet in operation, resists abrasion, wears at a low rate, and is easily molded, cast, or machined to close tolerances. Improvement in mechanical properties, rigidity, and wear resistance is obtained by adding fillers such as graphite and molybdenum disulfide to nylon. While the maximum recommended continuous service temperature for ordinary nylon is 170°F, and 250°F for heat-stabilized compositions, filled-nylon parts resist distortion at temperatures up to 300°F.
