How to split large wheel that doesn't fit the bed? September 23, 2015 07:20AM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 09:58AM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 11:40AM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 11:54AM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 01:11PM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 01:19PM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 05:34PM |
, it has about the same dimensions though. But you might be right, maybe have to find a solution to have it in one piece : -/|
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 07:20PM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 08:25PM |
etfrench
If you print the hubs separately, is there enough room to shift the pulley part on the bed and print one side, then shift and print the other side(s)?
p.s. If you're using PLA, then you can print on Acrylic and be able to shift the Acrylic piece with the PLA piece still attached.
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 09:09PM |
Re: How to split large wheel that doesn't fit the bed? September 23, 2015 09:17PM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 12:03AM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 02:44AM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 03:40AM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 04:27AM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 06:25AM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 11:59AM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 12:29PM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 03:05PM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 05:51PM |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 06:08PM |
Admin Registered: 18 years ago Posts: 14,142 |
Re: How to split large wheel that doesn't fit the bed? September 24, 2015 06:55PM |
VDX
... best compromise would be a laser-cut disc with all the round openings and extra fixture holes -- and 3D-printing all the complex parts ...
Re: How to split large wheel that doesn't fit the bed? September 25, 2015 03:23AM |
Re: How to split large wheel that doesn't fit the bed? September 25, 2015 05:21AM |
Re: How to split large wheel that doesn't fit the bed? September 25, 2015 06:44AM |
Re: How to split large wheel that doesn't fit the bed? September 25, 2015 07:20AM |
Re: How to split large wheel that doesn't fit the bed? November 10, 2015 10:26AM |
Re: How to split large wheel that doesn't fit the bed? November 11, 2015 04:46AM |
Re: How to split large wheel that doesn't fit the bed? November 11, 2015 06:34AM |
Re: How to split large wheel that doesn't fit the bed? November 11, 2015 07:11AM |
