Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 03:52AM |
Re: Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 07:50AM |
Re: Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 09:41AM |
Re: Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 10:48AM |
Re: Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 11:06AM |
How do you propose they know what orientation the polymers are facing, or if they are homogeneously oriented at all.Quote
Ezrec
Of interest, is that the polymer chains should go across the hinge, not parallel to it.
This implies that, unless they are laser-cutting this at a 45 degree angle to the orientation of the polymer chains, either the horizontal or the vertical hinges are going to fail prematurely
Re: Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 11:15AM |
Re: Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 11:20AM |
Re: Zatsit (that's it) delta printer "without" mecanics, your thoughts. September 29, 2015 12:19PM |
