How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 12:23AM |
or who knows what kind of crazy things can do for it
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 02:28AM |
Admin Registered: 15 years ago Posts: 7,333 |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 06:16AM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 07:54AM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 07:55AM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 08:56AM |
the_digital_dentist
Printed circuit boards, especially two or more layers, have been a PITA for hobbyists since PCBs were invented. ...
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 09:03AM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 09:59AM |
gnokix
Thanks John, this plan is which i saw before, unfortunatelly I'm not understanding it.Quote
jardern
Gnokix,
Please see the attached file. Hope this helps.
Regards,
John
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 10:38AM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 11:33AM |
ElmoC
If you don't understand the schematic, then trying to build one your self may not be an appropriate project. You would be better off to just buy one.
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 11:43AM |
ElmoC
gnokix
jardern
Gnokix,
Regards,
John
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 11:57AM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 01:27PM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 01:36PM |
george4657
You do not need the schematic to hook up the pins.
Look in your marlin files for pins.h and look for Ultra or LCD to find pins used.
Make sure you are looking for the pins on your motherboard type. You will find this definition in configuration.h.
You will also have to change configuration file to tell compiler you are using an LCD. Here again lookup lcd for options.
I have not used the graphics LCd only the 4 x 20 line so I can not help you with that.
There are a lot of different suppliers of these so google to find one with better instructions.
You will learn a lot more the way you are going but be prepared for the frustration. The joy of making it work is worth it to me.
George
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 06:11PM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 01, 2015 08:55PM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 02, 2015 09:18AM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 02, 2015 09:52AM |
sdavi
The full graphic LCD actually connects to a separate adapter board via 2 ribbon cables (labeled as EXP1 and EXP2 in the schematics), and the adapter board then plugs into the RAMPS board. The adapter board schematic can be found here reprap.org. In the adapter schematics, AUX3 and AUX4 are the pins used to connect to the RAMPS board, and it shows the connections of the RAMPS pins to the ribbon cables (EXP1 and EXP2). Then its just a matter of matching the pins of EXP1 and EXP2 in both schematics.
Edit: Here is AUX3 and AUX4 on the RAMPS board reprap.org
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 03, 2015 04:07PM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 06, 2015 03:57PM |
Hi tdd! thank you for posting, I know you're trying to help me and appreciate it.
george4657
George
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 28, 2015 05:56PM |
Re: How to make my own RepRapDiscount_Full_Graphic_Smart_Controller October 29, 2015 08:34AM |
chtipanda
Have you find a solution to operate the rotary knob
winking smiley thank you
