Re: New print surface material? October 31, 2015 01:30AM |
Re: New print surface material? October 31, 2015 02:55AM |
vendeta44
Side note: what i found worked well for leveling my print head with the printbite was getting it close then printing a large flat pane the size of my bed, after a few layers I could see what corners(4 point level bed) were lifting and I adjusted them then restarted the print and repeat. Maybe I'm crazy but it seems like the printbite wants the print head to be smooshed into it more so than glass.
Re: New print surface material? October 31, 2015 03:30AM |
Treito
Nice description. Can you give me some hints of the tape? As I am also not finding a suitable tape here in Germany mainly caused by having not enough data as I cannot find something like vinyl as no company gives exact data of their parts so I still only can guess. I may have found one tape which is extra strong which is also suitable for underfloor heating but I am not sure.
Your review sounds good and if I have 1kg less waste it would also save much money.
Re: New print surface material? October 31, 2015 03:41AM |
Mutley3D
Tape for vinyl flooring, NOT vinyl tape. I think you misunderstood
Re: New print surface material? October 31, 2015 10:18AM |
Re: New print surface material? October 31, 2015 10:27AM |
Re: New print surface material? October 31, 2015 10:51AM |
Re: New print surface material? October 31, 2015 10:58AM |
Re: New print surface material? October 31, 2015 11:14AM |
Re: New print surface material? October 31, 2015 11:15AM |
Re: New print surface material? October 31, 2015 11:22AM |
BriComp
I'm slightly confused. As I understand it you have the heated bed with Glasson the top of it held down with clamps. You then print onto Kapton tape which is stuck to the Glass.
Are you saying that the Glass is Warping, surely not?
Re: New print surface material? October 31, 2015 11:36AM |
Re: New print surface material? October 31, 2015 11:46AM |
Re: New print surface material? October 31, 2015 11:50AM |
Treito
BriComp
Of course not. The edges of the printed parts have a slightly lift off by around 0.2mm. This is enough for the sensor to get caught at the printed part for several reasons. One is the Auto-bed-leviling-function and the fact that the sensor is not nearby the printhead, If you know everything how the auto-leveling works and where the sensor is placed it is logical but hard to explain yet.
Re: New print surface material? October 31, 2015 12:05PM |
Re: New print surface material? October 31, 2015 12:36PM |
Re: New print surface material? October 31, 2015 11:43PM |
Re: New print surface material? November 01, 2015 11:36AM |
Re: New print surface material? November 01, 2015 04:04PM |
Re: New print surface material? November 01, 2015 04:07PM |
Re: New print surface material? November 01, 2015 05:18PM |
elwood127
You know, you could add tape to order. That way we don't have 30 feet sitting around for years to come.
Re: New print surface material? November 01, 2015 06:22PM |
Re: New print surface material? November 01, 2015 08:03PM |
Emmanuel
I have used polyimide, pmma, buildtak, printEZ, glass, glue stick... and for the moment I prefer the simple kapton tape or bare glass to the various polymer stuff.
Re: New print surface material? November 02, 2015 10:11PM |
Re: New print surface material? November 02, 2015 10:28PM |
Re: New print surface material? November 02, 2015 11:02PM |
Re: New print surface material? November 02, 2015 11:32PM |
Re: New print surface material? November 03, 2015 12:47AM |
Re: New print surface material? November 03, 2015 05:04AM |
